It is currently Sat May 25, 2013 1:13 pm
 Post subject: Trying to delete Windows 7 off second hard drive
PostPosted: Wed Jul 11, 2012 4:13 pm
I have two hard drives in my computer and both have Windows 7 Installed. I am trying to delete the Windows files in my secondary hard drive to free up space for other data, but every time I try to do so it tells me I don't have permission to do so. I already changed the folder ownership and set the permissions to allow me to have full control over the folders but still I am unable to delete the folders.
 Post subject: Re: Trying to delete Windows 7 off second hard drive
PostPosted: Wed Jul 11, 2012 5:02 pm
Format the drive.
PostPosted: Wed Jul 11, 2012 7:42 pm
You might have the boot sector on the second drive, or a page file. Windows 7 can do that if you had both drives working during the install. You can check this by disconnecting that drive you want to format and see if windows will boot up on the drive your wanting to keep windows 7 on. If it boots o.k. then disconnect the drive your keeping and connect the drive you want to format and use the Ultimate Boot CD. There are several disk wiping programs you can choose from to wipe the drive with
http://www.ultimatebootcd.com/
You just need to burn the .iso you download to make a bootable cd disk, set the bios to boot from your cd drive as the first device. Pop in the disk and boot up your pc. If you do not have anything to burn an .iso or have never burnt an .iso boot disk, you can get Image Burn for free
http://www.imgburn.com/
PostPosted: Thu Jul 12, 2012 3:26 am
Oh sorry, I forgot to mention I want to keep the other data so reformatting the drive is not what I wanted to do.
PostPosted: Thu Jul 12, 2012 3:39 am
The Ultimate Boot CD also has a program called Parted Magic. You can use the Shred program on Parted Magic to delete anything you like, your not running in windows so nothing about windows will prevent you from deleting anything you want
PostPosted: Thu Jul 12, 2012 3:50 am
Thanks Joe, I'm downloading it right now and will try it when it is done and see if it works.
PostPosted: Thu Jul 12, 2012 7:10 am
You could always take out the files you want, then format the drive.
Users browsing this forum: oldwizkid and 2 guests
