It is currently Thu Jun 20, 2013 2:39 am
 Post subject: network issue
PostPosted: Tue Jul 10, 2012 12:00 pm
I have a PC running Windows XP Pro
In the past, I could leave on my PC overnight, without logging off, and come back the next day and still have internet access, no problem.
Now for the last 2 weeks, every day I have to logoff and login (not rebooting) just to have Internet access working on my PC. :? The last I did was removed / uninstalled Avira antivirus free version and installed Microsoft Security Essential.
 Post subject: Re: network issue
PostPosted: Tue Jul 10, 2012 8:49 pm
How did you remove Avira from your computer? Did you use its built-in uninstaller or did you use RevoUninstaller to remove it? If you used the built-in uninstaller to remove Avira, it may have left behind file folders and registry entries that may be causing your issue. Also, have you tried resetting TCP/IP in Windows XP by using the netshell command?
PostPosted: Wed Jul 11, 2012 12:58 pm
what exactly is the nutshell command(s) do I type to reset them?
PostPosted: Thu Jul 12, 2012 4:22 am
Click on Start, then click on Run. In the field labelled "Open", type the following: netsh int ip reset log.txt, then click OK. A Command Prompt window will appear briefly, then it will disappear. After the command prompt window disappears, restart your computer. That should reset TCP/IP to its "pristine" state.
PostPosted: Thu Jul 12, 2012 4:55 am
Several ways to totally remove Avira:
http://www.themisteriosos.com/uninstall ... letely.htm
I would use Avira's uninstaller if you used that version.
