It is currently Tue May 21, 2013 11:49 pm
 Post subject: First build keeps crashing and restarting
PostPosted: Sun Jul 08, 2012 9:39 am
Hi iv just recentally made my first computer all parts from Newegg and after getting it all put together and installing Windows 7 64bit I was so happy it looked like everything turned out well.
Well guess what it dident, Whenever I try to do a windows update the computer will crash and restart. Or if I try to install drivers or something 80% of the time the computer crashes.
Its not just when i update or install something it also happens randomly when im on the desktop. Iv tried navigating through forums for similar things but i couldn't find anything, I have also tried reinstalling Windows twice now. Im not great with computers im more in the moderate area when it comes to knowledge of how they work.
System Specs:
Power Supply:Antec Earthwatts Series Ea-750W ATX12V v2.3 sli certified Crossfire certified
Operating system: Windows 7
Ram: Corsair Vengence 16GB (4x4GB) 240-pin DDR3 SDRAM DDR3 1600 (pc3 12800)
Case: Antec Nine hundered
Processor: Intel Core I7-3770 Ivy Bridge 3.4GHZ (3.9GHZ Turbo) LGA 1155 77W Quad-Core Desktop Prossor Intel HD Graphics 4000
Motherboard: Intel Boxdh77kc LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 Atx Intel motherbored
Dvd/bluray: ASUS Black Blue-ray Drive Sata Model BC-12b1st/blk/b/as OEM
SSD: ADATA s510 Series As510s3-120GM-o 2.5"120GB Sata 3 MLC internal SSD-OEM
Thanks in Advance, I really dont know what to do iv been saving up for this computer for over 2 years now.
 Post subject: Re: First build keeps crashing and restarting
PostPosted: Tue Jul 10, 2012 10:24 am
Did you just let windows install genaric drivers or did you use the disk that came with the motherboard to load the chipset drivers, video driver, sound drive, nic driver ectra....?
PostPosted: Tue Jul 10, 2012 8:51 pm
This sounds like a RAM issue. Have you tried running memTest86+ for several passes to determine if you have any failing memory addresses in your system memory?
PostPosted: Wed Jul 11, 2012 12:42 am
There are so many things that can cause random system crashes, (BSOD), etc.
As others have mentioned, memory issues, motherboard drivers, etc.
Did you remember the TIM? Was the TIM applied correctly? How do your temps look? Is the CPU over heating?
What BIOS settings are you using? Is there enough Vcore voltage? Low Vcore will cause random system crashes.
You'll need to eliminate one at a time.
