It is currently Mon May 20, 2013 10:48 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: My PC is failing to boot
PostPosted: Sun Jul 08, 2012 3:54 am
Who knows who made the reviews... if you are talking Tom's, Max Pc, Anandtech, ok; not users!
PostPosted: Thu Jul 12, 2012 5:08 am
It's your PSU.
Quote:
I have a self built PC that is not booting, I know the power supply works, as all the fans and lights turn on,
No...you don't. All you know is that your PSU is able to turn the fans and lights on. It's your PSU. All your comments suggest this:
*It's 3 years old (EDIT: I may have made this up...I just re-read the post and it only mentions last Xmas. Still, it's your PSU)
*fans and lights turn on - very typical of a failing PSU. Often makes you think it must be something else because, well, fans and lights turn on.
*I've learned from experience, THE most likely component to fail is the PSU.
It's your PSU.
Hope this helps.
PostPosted: Thu Jul 12, 2012 2:36 pm
btdog wrote:
It's your PSU.
It's your PSU.
Hope this helps.
I've tested the psu, and it works, besides, I replaced the motherboard, and it all works very well now. So now this thread is solved.
