It is currently Tue Jun 18, 2013 4:16 pm
 Post subject: What is going on!!!!!!!!!!!!!!
PostPosted: Mon Jun 11, 2012 3:03 pm
Hello every one hope you can help me out,i don't know what going on with my PC, but i cant play 1080p videos. I don't know if its the display monitor that affect my video or the processor i have posted a link to the picture to show what i have in my system.if you need more info let me know. one more thing my secondary Hard drive is slow to read files ( SEAGATE 1TB) also if i need to upgrade something let me know
thanks for all you help :D
 Post subject: Re: What is going on!!!!!!!!!!!!!!
PostPosted: Tue Jun 12, 2012 6:58 pm
Define "can't play". Video stuttering? No video? What?
PostPosted: Tue Jun 12, 2012 8:36 pm
What videocard are you using in your rig?
PostPosted: Wed Jun 13, 2012 8:12 am
9800gt, eyes going bad. :)
how are you connected to the monitor?
PostPosted: Wed Jun 13, 2012 10:15 am
To g.m.waters: Yeah, I missed that information from the original post. My bad!!! :oops:
PostPosted: Thu Jun 14, 2012 7:09 am
That is an old system, what games are you trying to play on it?
PostPosted: Thu Jun 14, 2012 2:11 pm
well i have my pc hook to the monitor via DVI and i play mostly cod 4 and xfire read 100 to 115 FPS and i know that cant be right
PostPosted: Thu Jun 14, 2012 2:14 pm
video stutters at 1080p on youtube and videos from my dslr camera but can play 720 just fine
PostPosted: Thu Jun 14, 2012 2:40 pm
this original was a HP system until the motherboard went out due to insufficient power and then bought the case.
PostPosted: Fri Jun 15, 2012 8:44 am
That system just isn't built for todays games....time to upgrade to a better system.
PostPosted: Sun Jun 17, 2012 10:19 am
When you play those videos, check your CPU usage in task manager. If you're constantly at 100%, your processor isn't up to snuff.
PostPosted: Sun Jun 17, 2012 2:46 pm
okay so i went to youtube and found a video in full hd and i put it in 1080p,definite stutter and cpu goes up around 30% to 60% PF usage around 1.22GB i feel something is limiting the memory.i going to see if i can make a video to show what happening.
PostPosted: Mon Jun 18, 2012 8:16 am
Do you know what the max resolution of your monitor is?
This is fairly easy to check out.
Check out the available resolutions from your nvidia or display control panel.
In order to do 1080p, it should be capable of at LEAST 1920x1080.
Also, try hooking it up to an HDTV that does 1080p, if you have one available.
You might need to convert the DVI to HDMI with a DVI-to-HDMI cable.
Obviously, you don't want to downgrade the signal to VGA.
PostPosted: Mon Jun 18, 2012 12:42 pm
1680x1050 is the max res. i do have a hdtv so i will try that out
PostPosted: Thu Jun 21, 2012 5:35 am
The fact is that I can't clearly get your problem from the screens.
More details?
If you still need some help - write to me)
