It is currently Wed May 22, 2013 2:39 am
 Post subject: Why does computer shut down and restart
PostPosted: Sat May 05, 2012 8:22 pm
My computer is shutting down and staying off some times other times it is shutting down and restarting. I kown this must be a over heating problem but i do not know the best way to fix it. I have some ideas but I would rather get some ideas on here. It also is making the sound when you unplug and plug in anything from the usb port with out me doing anything. Any ideas would be much appreciated.
 Post subject: Re: Why does computer shut down and restart
PostPosted: Sat May 05, 2012 9:35 pm
is it a desktop or a laptop?
PostPosted: Sun May 06, 2012 7:58 am
If it appears random, it might be BSODs. If you can...
  • Right click on "Computer", select Properties
  • On the left side, select "Advanced System Settings"
  • In the "Startup and Recovery" box, select the "Settings" button
  • Uncheck "Automatically restart"
See if this pops up with a BSOD, and if it does, really the stop error here.
Alternatively you could look through your event logs in Control Panel -> Administrative Tools -> Event Viewer in the System category.
PostPosted: Sat May 12, 2012 3:51 am
I have faced the same problem .
-may be the problem is in your RAM
-problem in your restart button
-problem in BIOS
-paste under the cooling fan may become dry
-cooling fan my not properly work
try to find out what is your problem & solve it
PostPosted: Mon May 14, 2012 9:45 pm
My laptop sometimes like that, but I think it because due to overheat. So what I do is have it near the fan to make more air inside the computer and make sure that when it restarts, it fixes and recovers everything.
PostPosted: Wed May 16, 2012 6:04 pm
I'm using a desktop here.
Users browsing this forum: CharBroiled and 4 guests
