It is currently Mon May 20, 2013 11:09 pm
 Post subject: How to update Adobe Flash Player correctly?
PostPosted: Wed Apr 04, 2012 10:55 pm
I did some test of my Firefox Browser with Qualy's Browser Check plugin (a big thank you to Maximum PC :D) and it found 2 Security Issues, namely, Adobe Flash Player and Silverlight.
I downloaded Adobe's Flash Player update and installed it, then re-do the test and it still shows the same result. What gives? o-0
 Post subject: Re: How to update Adobe Flash Player correctly?
PostPosted: Thu Apr 05, 2012 4:12 am
Just go to the Adobe Flash site and update it there, the same goes for Silverlight.
http://get.adobe.com/flashplayer/
http://www.microsoft.com/getsilverlight ... fault.aspx
PostPosted: Thu Apr 05, 2012 7:28 am
I have downloaded the update from adobe site and installed it, yet it still says I am using an outdated version of Flash player.
PostPosted: Thu Apr 05, 2012 7:42 am
Use this site then:
http://www.mozilla.org/en-US/plugincheck/
PostPosted: Fri Apr 06, 2012 10:11 pm
Nastyman wrote:
Cheers mate. It shows the Adobe Flash Player is up to date now. :)
PostPosted: Sat Apr 07, 2012 3:36 am
Plugs all those security leaks... :wink:
