It is currently Sun May 19, 2013 7:31 pm
 Post subject: I get sound, but my soundcard drivers won't properly
PostPosted: Sun Apr 01, 2012 5:11 pm
I currently have a PCI-e soundblaster X-Fi, the card suddenly doesn't pick up my mic, I cannot use the apps that come with the card. I still can get sound, but it sounds like the on board sound. I have done everything from driver sweeper, deleting files, and running uninstall and the problem still persist. When I try to open the contorl panel, the system tells me that there is no device installed, when I go to check it out, the drivers have installed, but I tried to re-install like 4 times and getting the same result. Is there anything that I am missing or is there something else going on?
 Post subject: Re: I get sound, but my soundcard drivers won't properly
PostPosted: Sun Apr 01, 2012 6:19 pm
First things first: Look at your mobo manual to see how to disable the onboard sound in your BIOS. Some boards say to set it to "Disable", others say set it to "Auto".
PostPosted: Sun Apr 08, 2012 7:31 pm
I disabled the onboard sound. I noticed another problem, I had two other programs system mechcanic and autocad decided not to work at all, all of these are installed on my primary drive. I have been thinking that I may have a dying drive for a while, I bought it back in summer of 08'. I have noticed occasionally that t has legged a bit here and there, I oc'd amd 955 to 3.8Ghz and 8 G's of ram. when I start doing multible stuff at the same time, the system freezes and forced me to shut down.
Users browsing this forum: Exabot [Bot] and 3 guests
