It is currently Sun May 19, 2013 11:48 pm
 Post subject: IRQL_NOT_LESS_OR_EQUAL upon boot -> Restart OK
PostPosted: Tue Apr 03, 2012 12:43 am
This is not an emergency for myself, but I figured getting some input would help me understand the common error, and a possible fix. When I boot up my computer, I receive a BSOD labelled IRQL_NOT_LESS_OR_EQUAL once the OS is loaded and presents the Windows7 login page. Once the BSOD reads the memory dump, it reboots and works fine. I am glad to be able to login, but I would like to understand this error before I may possibly run into further errors. Anyone know what this BSOD dictates typically?
Core i5 750
6GB OCZ Platinum 1333MHz
Asus Maximus III (micro ATX)
Seagate Barricuda 500GB 7200RPM (Windows 7 OS)
WD Velociraptor 150GB 10000RPM
GTX 280(SLI)
GTX 280(SLI)
Ultra 1150Watt PSU
 Post subject: Re: IRQL_NOT_LESS_OR_EQUAL upon boot -> Restart OK
PostPosted: Tue Apr 03, 2012 1:36 pm
Usually that error is related to a driver that does not start properly when windows is trying to load. First step I would do is make sure that all your drivers for all your hardware are up to date.
PostPosted: Tue Apr 03, 2012 2:47 pm
Look in Device Manager for problems with devices. Also look in Event Viewer for errors in the system and application logs.
