It is currently Fri May 24, 2013 6:34 am
 Post subject: Pissed girlfriends and Vista Password Recovery
PostPosted: Wed Mar 28, 2012 3:59 pm
As you can tell by the title of my posting, an explanation of what happened to my buddy is not necessary.
Suffice it to say, she is now an ex-girlfriend and he is locked out of his computer. Even Dr. Phil couldn't mediate this break-up.... which is now heading towards Jerry Springer status. I got recruited to rescue the poor guy.
If it had been an XP install, I would have had the password issue solved by now - but Vista has me stumped. I already tried Ophicrack and at least two other bits of freeware to no avail. Any suggestions for a workaround short of reinstalling Windows?
 Post subject: Re: Pissed girlfriends and Vista Password Recovery
PostPosted: Wed Mar 28, 2012 6:04 pm
If it's just the files you want and there's no TrueCrypt or something, plop the hard drive into another computer. And hell, if it's Linux with NTFS support, it doesn't give a damn about permissions (or so people tell me).
PostPosted: Thu Mar 29, 2012 2:18 am
Yup - that would be the easiest solution. There is no problem backing up the files using Linux or Solaris. I was just stupid to say that I could reset the password thinking that he was still running XP. :? We had made the barter arrangement for him to change the sparkplugs in my Sienna (NOT a fun job) and now I am on the hook for this. Next time I will keep my mouth shut!
PostPosted: Thu Mar 29, 2012 8:26 am
And even if you're running Windows, it doesn't really care about another install's ACLs as much. Just change the permissions of the folder with all the files so that you have full access.
And I believe the recovery mode console also doesn't really care. But this is just me going on the belief that I deleted an XP Mode user folder in recovery mode because Windows itself wouldn't let me change the permissions (somehow System wasn't included in full control...)
PostPosted: Thu Mar 29, 2012 2:01 pm
Read this, it is about ophcrack, I know you tried but read this anyway.
http://www.wintuts.com/Retrieve-your-Wi ... h-Ophcrack
Download this copy:
http://ophcrack.sourceforge.net/downloa ... e=ophcrack
Try following the instructions to the letter and let us know how you made out.
PostPosted: Thu Mar 29, 2012 6:38 pm
Thanks! I most certainly give this a shot tomorrow!
:D :D
PostPosted: Tue Apr 03, 2012 6:48 pm
OK - as I sit here I am getting the message "No tables found."
Am I correct in assuming that this is not good?
PostPosted: Wed Apr 04, 2012 4:54 am
If you have two cd-roms or more unplug all but one and try the cd again.
PostPosted: Wed Apr 04, 2012 8:55 am
Thanks - will do.
PostPosted: Wed Apr 04, 2012 12:46 pm
Well I checked for to see if there were extra DVD drives in the computer.... unfortunately there is only the one that I used to run Ophicrack. I was really hoping that would be a quick and easy solution. Then Murphy and his damn law had to show up. Any suggestions or alternatives?
PostPosted: Wed Apr 04, 2012 2:07 pm
I take it plugging the HDD into another computer or an external enclosure is out of the question? The worst that would happen on a Windows machine is that Windows thinks you don't have access rights to the user folders (which is changed by going to the properties and changing who owns it).
PostPosted: Wed Apr 04, 2012 2:19 pm
Sounds like a possibility! Thank you!
PostPosted: Thu Apr 05, 2012 4:07 am
It won't boot because you will have the wrong chipset drivers. If it does, it will mess up the drivers you now have installed.
PostPosted: Thu Apr 05, 2012 9:02 am
What I'm saying is, if there's important data in there, you can just plug it in another computer as a secondary data drive, grab what you want, and reinstall Windows on that drive. And if there's any Windows file permissions making that part hard, you can change them as an Admin. OP already can't log in anyway, so there's no point in plugging it in as a boot drive.
PostPosted: Thu Apr 05, 2012 4:02 pm
Yes, you can do that as a secondary hard drive...didn't quite sink in what you wanted to do...
PostPosted: Sun Apr 08, 2012 4:22 am
You can get the Ultimate Boot Cd here
http://www.ultimatebootcd.com/
Under Data Recovery, you can use Offline NT Password and Registry Editor
read this tutorial
http://pogostick.net/~pnh/ntpasswd/
PostPosted: Thu Apr 19, 2012 9:59 am
Problem resolved! It turns out that were two issues conspiring against me. First, the DVD-Rom was at the point of failing and any password recovery methods would not work. Once that was replaced, the whole process went along further, but still would not work no matter what application I threw at it. At the end I tried the password recovery DVDs on another PC I had laying about and all of them worked. It was only after I was given the password (long story) that I discovered that the whole Windows installation was fouled up beyond all repair. Thankfully the recovery disks did manage to restore teh beast, but not before it was a huge pain in the ass.
PostPosted: Thu Apr 19, 2012 1:12 pm
....so next time before your buddie pisses off the girlfriend, hide the machine. :twisted:
PostPosted: Fri Apr 20, 2012 10:07 am
3 Words. Hirens Boot CD
http://www.hirensbootcd.org/files/Hiren ... D.15.1.zip
In one of the options you will see a utility for
Offline NT Password
Here is how to use it
http://pcsupport.about.com/od/toolsofth ... -guide.htm
PostPosted: Wed May 02, 2012 10:09 pm
Download this copy:
Thanks for your efforts and suggestion, but unable to open your suggested link..is it working fine...
pls suggest me... its important reference ...help me out.
