It is currently Sat May 25, 2013 12:09 pm
 Post subject: Hard Drive Size Question
PostPosted: Mon Jan 23, 2012 3:09 pm
I may be wrong but I thought I read that Win7 OS's have problems with 3 TB hard drives. If that is true, is the problem only when the OS is put on it? Cause I plan to use it only as a slave drive.
 Post subject: Re: Hard Drive Size Question
PostPosted: Mon Jan 23, 2012 4:51 pm
There are no problems as long as you are running 64 bit Windows (which most installs are.) and a motherboard with UEFI/EFI (which many newer ones are...).
PostPosted: Mon Jan 23, 2012 7:41 pm
Win 7 is actually the cure, not the problem with the caveat that you're running 64 bit
This should probably answer most questions with this...
http://www.pcworld.com/article/235088/e ... rives.html
