It is currently Sun May 03, 2015 9:05 pm
 Post subject: Adobe Acrobat wont run
PostPosted: Fri Jul 23, 2004 11:03 am
I have Acrobat 6 Pro installed on a machine running Windows 2000 Server. It always worked fine until one day last week it would "freeze" up at the startup window and never launch. I have tried to uninstall/reinstall with the same result. I have even installed the "free" reader and it does the exact same thing.
Has this happend to anyone else? Any suggestions or help would be greatly appreciated.
PostPosted: Fri Jul 23, 2004 11:45 am
check for the pop-under update dialog box.
if that doesn't exist, then try re-installing Acrobat Reader to see if it goes away.
PostPosted: Fri Jul 23, 2004 12:46 pm
Have you tried to run a "repair" using your win 2000 disk? You may have a bad file or two in your system files. Don't forget to go to microsoft for updates after the repair.
 Post subject: Re: Adobe Acrobat wont run
PostPosted: Fri Jul 23, 2004 5:17 pm
Try re-installing the Microsoft Journal Viewer. I use Acrobat 6 on a lot of 2000 machines, and it breaks sometimes. Oddly enough, re-installing the Journal Viewer fixes it.
http://www.microsoft.com/downloads/details.aspx?displaylang=en&familyid=fad44098-8b73-4e06-96d4-d1eb70eacb44
PS. I just noticed that you said Acrobat 6 Pro. I thought you meant Acrobat Reader. I'll leave this here anyway. It may help.
PostPosted: Fri Jul 23, 2004 6:24 pm
you might want to check for a virus or something like that. maybe even windows updates.
