It is currently Mon Apr 27, 2015 11:40 pm
 Post subject: A browsing problem
PostPosted: Thu Jul 22, 2004 2:38 pm
When i'm browsing a folder on my C: drive (c:/music etc...) the window closes and i'm brought back to my desktop...howcome?
I defragged and virus checked)
Any ideas why?
 Post subject: Re: A browsing problem
PostPosted: Thu Jul 22, 2004 2:40 pm
Any ideas why?
What AV program are u using? Did you scan for spyware? Is your OS up to date?
PostPosted: Thu Jul 22, 2004 3:34 pm
XP SP2 uptodate - AVG free AV
and yes spyware and ad aware - just checked
PostPosted: Thu Jul 22, 2004 3:42 pm
Anything found? You can try housecall at housecall.trendmicro.com, which is a free online virus scanner. Are AVG and ad-aware up to date as well?
PostPosted: Thu Jul 22, 2004 3:45 pm
Any ideas why?
this sounds somewhat similar to another type of worm that closes task manager, regedit, gpedit.msc, etc.
http://www.mcse.ms/message774027.html
Try an online virus scanner as those often pick up viruses that are not detected by AVG, NAV, McAfee:
http://www.pandasoftware.com/activescan ... ncipal.htm
PostPosted: Thu Jul 22, 2004 4:23 pm
fixed.
Another problem: When I open a video file (avi, divx), windows media player retarts and i'm forced back to desktop...
I think it's a codec porblem, ever since i installed nimo codec pack i've been experiencing this problem...I unistalled it...but still i have the porblem...what should I do?
btw i can play avi files in video lan fine
PostPosted: Fri Jul 23, 2004 12:20 pm
XP SP2??? I thought they are not released yet...
PostPosted: Fri Jul 23, 2004 6:08 pm
Folding Master (Top-ranked)
It is available as release canidate 2. sp2 rc2 270 meg. download.
PostPosted: Fri Jul 23, 2004 6:18 pm
if you uninstalled your nimo codec try installing a new codec that is comparable to nimo or even reinstalling the nimo codec. ive used it for a long time and never had problems with it before. maybe you got a bad codec.
