It is currently Tue Mar 03, 2015 3:02 pm
 Post subject: Sound problem after installing new vid card
PostPosted: Thu Jul 22, 2004 1:48 pm
I recently installed a new video card (geforce fx 5200 pci) with a fresh installation of windows xp. After i got it all working, i starting listening to winamp. the sound quality wasn't that good. Then i start moving the cursor across the screen really really fast, repeatedly, and every time i did, the speakers would start playing static like bad reception on the radio. It happened anytime i did anthing with that required cpu cycles, even when music wasn't playing (but not nearly as bad).
What could cause this problem? Is there megnetic interference? Is my pci bus just not strong enough to handle this video card alongside the other pci components?
my comp spec... (save the laughing and heckling for later)
pIII 667mHz
jetway 993AN rev1 mb
320mb ram
40gb + 160gb
LG 16x10x40
soundblaster 16
17" KDS monitor
400w power supply
I've tried swapping the locations of the pci cards, but that didn't work, i bought the 400w power supply after the card and got rid of the old 250w but that didn't work. I've posted this at a few messageboards but with no avail..
I know it's a pci and that an agp would be better but when someone offers you a free video card (brand new), i'm not saying no. I'm upgrading from a voodoo3 2000 pci.... (a classic, don't even thing about laughing at that)
Buying a new motherboard, or any other new components aren't really options that i can exercise at this momment. Yes, i know, a new system all together would be the best option, but as a former student supporting myself, i just can't afford it right now...
thanks,
mm
PostPosted: Thu Jul 22, 2004 2:39 pm
how much free RAM and what CPU utilization do you have when you use winamp?
I think your PC is a bit too underpowered for Windows XP.
PostPosted: Fri Jul 23, 2004 7:53 am
about 50% of my ram is available. winamp 5 uses about 20-30% and winamp 2.91 uses 12-20%
i've been running xp on this comp for years now, and had no problems until i tried installing this video card.
PostPosted: Fri Jul 23, 2004 8:04 am
what output are you using with WinAmp? DirectSound or wav? maybe after installing the video card and its driver/software, your DirectSound was messed up.
PostPosted: Fri Jul 23, 2004 6:04 pm
i too ran a 600 mhz windows xp rig except mine was a celeron so that shouldnt be a problem. does your machine do the same static sound if you use other sound programs?
PostPosted: Tue Jul 27, 2004 5:34 am
I usually use direct sound, but i tried switching it up, and no luck..
I also tried other programs like windows media player and still the same problem..
