It is currently Sun Apr 26, 2015 10:14 am
 Post subject: sluggish performance during bootup and when laptop is on
PostPosted: Wed Jul 21, 2004 2:24 pm
Hi you all:
Laptop Dell Latitude CPx 750 MHz 256 mb ram ATI Mobility Rag vid. Card w/ 16 meg On it.
My computer literally crawls while booting up and while on. Running msconfig did not do any good. I remember an article in Max PC Mag last year that had step by step instructions on how to kill the culprits who resided on system resources as hogs at the boot time. I also have some programs that installed themselves on my machine while surfing the internet[my wife is the culprit] that I want to weed out and increase the performance.
Is that my only problem? Or need more cleanup?
Please help
[/code]
PostPosted: Wed Jul 21, 2004 2:30 pm
dump Internet Explorer
download both Ad-Aware and Spybot S&D and run them once a week.
make sure you a running a firewall (hardware or software or both)
don't install crap like Kazaa.
PostPosted: Wed Jul 21, 2004 3:06 pm
Celeron
Celeron
If you have your MaximumPC mags ready, go and get your april 2004 issue and go to pg 32. Follow the instructions under "Lower Your Boot Speed to 15 Seconds" Be sure to note BootVis
PostPosted: Wed Jul 21, 2004 4:35 pm
King of All Voodoo2 Cards
Also, one last suggestion if you can spring for a new HDD, do it.
I replaced the 30GB 4,200 RPM 2MB Toshiba HDD that came with my laptop back in 2001, with a 40GB 5,400 RPM 16MB Toshiba HDD and it cut my boot time literally in half.
But definitely get Ad-Aware and Spybot and clean that crap off your HDD.
PostPosted: Thu Jul 22, 2004 6:40 am
the Aug 2004 issue also speaks a bit about boot times
PostPosted: Thu Jul 22, 2004 2:22 pm
Spy Sweeper from www.webroot.com is a good program also, but only for limited use.
