It is currently Mon Apr 20, 2015 10:49 pm
 Post subject: hdd plus
PostPosted: Thu Dec 09, 2010 12:32 am
i have been hit with this virus and have tried malware bytes and spybot to destroy it but no luck
 Post subject: Re: hdd plus
PostPosted: Thu Dec 09, 2010 8:53 am
Malware specialist
Malware specialist
If it's just HDD Plus, you can try using this removal guide.
It does mention to use Malwarebytes' and I suggest running again. Be sure to update the program and run the full scan as mentioned in the guide.
PostPosted: Thu Dec 09, 2010 9:25 am
To better help with the situation we would need more information. There are so many viruses out there and in turn many different paths to follow to remove viruses. There is no one sure way to get rid of a virus. I deal with viruses everyday. Please give more information and someone here might be able to help you out.
PostPosted: Thu Dec 09, 2010 9:39 am
See now I feel kinda dumb. I read the message but didn't read the subject. I was wondering why hackman posted the instructions for that virus.
Anyways if those instructions do not work, then let us know.
