It is currently Wed Mar 04, 2015 7:51 am
 Post subject: Video card or monitor? Screen goes black when switching user
PostPosted: Sun Dec 05, 2010 11:09 am
I have an issue with my Acer P221W monitor going black when I switch user profiles on my Win 7 PC. It only happens on random occasions but it's enough to be frustrating; a few times a week at least, sometimes once a day depending how much use the PC gets throughout the day.
The original post is here but at that point I thought it was a problem with the OS.
Last night this happened again so I decided to unplug the monitor cable going into the video card (Radeon 4870) and plug it back in. Sure enough, when I plugged it back in the monitor came back to life. So now I'm wondering if it's hardware related. All my video drivers are up date and besides, this has been happening for quite some time (more frequently lately however). There are no Win 7 64-bit drivers for the monitor and certainly no firmware updates.
I'm at a loss as to what to do.
 Post subject: Re: Video card or monitor? Screen goes black when switching
PostPosted: Sun Dec 05, 2010 11:25 am
Have you tried switching out the cable between the monitor and video card with another cord to see if it is the cord?
PostPosted: Sun Dec 05, 2010 12:15 pm
I don't have another VGA cable.
I realize that's the obvious step in troubleshooting but the way the monitor behaves (only blacks out when switching users) I'm more inclined to believe it's a device issue. Not sure how a cable could become flakey only while switching users. I'm sure stranger things happen though. Not much I can do without a cable at the moment...
PostPosted: Sun Dec 05, 2010 12:22 pm
Is the other user running different res?
PostPosted: Mon Dec 06, 2010 11:42 am
No, but good idea!
PostPosted: Mon Dec 06, 2010 11:48 am
No, but good idea!
Set both users to same res. See what happens.
Maybe a cap(s) on the LCD board is buldging/blown. Can't handle res changes without going black.
PostPosted: Wed Dec 08, 2010 10:22 am
Na, everyones running the default res for that monitor.
PostPosted: Wed Dec 08, 2010 4:32 pm
Team Member Top 1000
The most sure fire way to find out is really to just swap stuff out and test. You got any old stuff laying around you can swap?
PostPosted: Thu Dec 09, 2010 10:17 am
I would agree with FrostyWinnipeg. Even if your not changing Res it sounds to me like a blown Cap. If this is what it is then this is an easy fix if you know how to Solder. Open the monitor. Look at the circuit boards. Find a cap with where the head of it has rounded. Capacitors should have a Flat head. When they get rounded then you know it has blown. Then use the Solder Iron to remove the cap. Take it to Radio Shack to buy a new one just like it. And then Solder in the new Cap.
