It is currently Wed Jan 28, 2015 2:02 am
 Post subject: cdrom0 has a bad block, per event manager > upgrade to XP
PostPosted: Tue Jul 20, 2004 6:33 pm
Does anyone know the cause of this problem? Symptoms are slow boot and problem reading the (in this case) Lite-On Cd/DVD-ROM. Various forums have reported the problem but I have found no solution. I formatted disk using Seagate's drive prep s/w (current version), HD is not new but never a problem, installed WIN 98 & upgraded to XP using an OEM disk and now Event Manager shows CD & ATAPI problems ID'ed as 7, 9 & 51. CD/DVD was in another computer with no problem, replaced cable - no help, can't use lens cleaning disk as drive will not run it. Have an API log that looks like it might show a problem but I hesitate to post it as a bit late for me & maybe overkill now. Should I just reformat & reinstall or is there a less time consuming solution. Thanks
PostPosted: Wed Jul 21, 2004 8:57 am
this may seem like a dumb question, but is your CD-ROM empty?
PostPosted: Wed Jul 21, 2004 5:30 pm
I think empty at boot up, but tried to install a driver from cd drive
PostPosted: Wed Jul 21, 2004 5:46 pm
well, a slow boot can be caused by a myriad of things, so that is most likely not related to your other problem.
is your computer is slow only when you try to use you CD-Rom or is it more constant.
What I am thinking is that you are trying to use a badly damaged CD. If your problem is more constant then there is something else.
