It is currently Fri Feb 27, 2015 10:05 pm
 Post subject: Windows XP slow shutdown
PostPosted: Tue Jul 20, 2004 9:45 am
I've seen tips on making XP load faster, but how about getting it to shut down faster? Anyone have any tips?
PostPosted: Tue Jul 20, 2004 10:44 am
check out www.jsiinc.com and see if you can find anythin on this website dealin with your topic. you can find alot of stuff from this site and it all deals with windows. check it out. also maximumpc just release their unauthorized summer 2004 magazine which gives top of tips and tricks in mastering windows xp.
i have the mag and i was looking for your problem and im sure i saw something here dealing with having winxp shut down faster but im in a hurry. gotta go do somethign real quick. when i come back ill find it and post it to you. later
 Post subject: Re: Windows XP slow shutdown
PostPosted: Thu Jul 22, 2004 3:19 pm
Yea make sure to exit any programs before shutting down will speed it up. Also make sure if you have any AV or spyware removal programs that they do not have any settings to scanning the drives at shutdown.
You can also turn off any additional services you are not using and this will speed up shutdown. They are websites that you can find on google that will tell you what all the services do and if they are safe to turn off in windows.
