It is currently Sat Apr 25, 2015 1:59 pm
 Post subject: November 2003 How to : Pocket PC Movies NO SOUND
PostPosted: Mon Jul 19, 2004 11:02 pm
Hi all,
First timer on the message boards, thought someone might be able to tell why when I followed the Max PC how to for creating a PDA movie from DVD that after the Tmpegenc encoding, I had no sound in the .MPG. The article tells you not to select an audio source as the .D2V project contains the audio, But I think this is in error
Any Suggestions
Chris
PostPosted: Tue Jul 20, 2004 8:35 am
I use TMPGEnc all the time so I know that is not the problem.
Try setting the Audio Source in TMPGEnc to the .D2V file in TMPGEnc and see if that helps.
