It is currently Tue May 05, 2015 4:19 am
 Post subject: Highest vcore to set for Athlon XP 2500+
PostPosted: Sat Jan 15, 2005 1:01 am
Hi, I have my Athlon XP 2500+ running at 3200+ speeds with a 200MHz FSB. I've brought my vcore up quite a bit to get it running stable and currently have it at 1.8V which actually registers at around 1.83. Is this already too high or at what voltage should I stop at. The temp is 52 celcius and the system temp is 29.
 Post subject: Re: Highest vcore to set for Athlon XP 2500+
PostPosted: Sat Jan 15, 2005 7:45 pm
The higher voltage you use, the better cooling you need. 52C is kinda scary. What are you using for cooling?
PostPosted: Sat Jan 15, 2005 8:50 pm
Celeron
Celeron
Did you give the Vcore small little bumps until you found complete stability? Or did you just jump from 1.65v to 1.8v?
PostPosted: Mon Jan 17, 2005 12:20 pm
wow thats a little high... Id step the voltage down a bit not to mention the heat is a little high may cause this system to run a little unstable. basically i think the rules with over clocking are simple. Dont touch the vcore till last absolutely last. I always try to achieve the highest speeds without adjusting the vcore. in fact im running the same barton core 2500 and im running stable with my temps at 43c on max load. 12.5x multiplier and fsb at 190. vcore is still untouched.
