It is currently Tue Jan 27, 2015 2:51 am
 Post subject: A AMD Mobile Athlon XP or AMD Athlon XP
PostPosted: Sat Jan 01, 2005 2:47 am
I'm looking at buying a Processor for my ASUS "A7N8X-E Deluxe" nForce2 Ultra 400...Looking at the AMD Mobile Athlons XP 2500+,2600+,3000+....And the AMD Athlon XP 3200+ "Barton", 400MHz FSB, 512K Cache Processor...I will be using Corsair XMS Extreme Memory Speed Series, (Twin Pack) 184 Pin 1GB(512MBx2) DDR PC-3200 or Kingston HyperX Series Dual Kits 184 Pin 1GB(512MBx2) DDR PC-3700... I also have a BFG nVIDIA GeForce 6800 Ultra Video Card...I will be overclocking the cpu and or the memory....Need help picking with one....Thanks for any help you can give me.... :)
PostPosted: Sun Jan 02, 2005 11:36 am
Celeron
Celeron
Get the 2500+. If you can, get the Mobile 2400+. It's only 30MHz slower than the 2500+.
