It is currently Sat Apr 18, 2015 12:18 am
 Post subject: Registry Hack to get nVidia OC active ??
PostPosted: Sun Dec 26, 2004 2:06 pm
I have seen in a magazine (can't remember which one) that there is a registry hack that will allow access to an OCing section of the nVidia drivers.
Does anyone know how to do this ? I can't remember and its not too hard. It will even set an optimum OC speed for your card automatically, if you wish.
Thanks for any info.
PostPosted: Sun Dec 26, 2004 2:25 pm
Celeron
Celeron
Your answers can be solved at [url=google.com]google[/url].
Clicking on the second link you get from the search hook "coolbits", you get this link.
Glad I could help! :P :wink:
PostPosted: Thu Dec 30, 2004 2:58 am
I've posted it in here recently, but here it goes:
  • Open Regedit
  • Travel to HKLM\software\NVIDIA Corporation\Global\NVTweak
  • With "NVTweak" still highlighted, right-click in the right window pane
  • Select new -> DWORD value
  • Name this new word "CoolBits" (it's not case sensitive)
  • double-click the new Coolbits DWORD to open the value's properties box
  • In the "value data" box, enter "3" and insure that the Hexadecimal selection is checked
  • Exit Regedit
Now, when you right click on the desktop, properties -> settings -> advanced, the tab with all the performance settings should have a new option called "clock frequency settings". You can manually adjust from here...
The latest drivers now flash a user agreement at you when you go to manual each time, and you have to scroll through the thing like you're actually reading it before you can check "agree". Other than that, it's a great little utility.
(HKLM= "HKEY_LOCAL_MACHINE")
