It is currently Tue Apr 21, 2015 5:18 am
 Post subject: FX-55 overclock
PostPosted: Wed Oct 27, 2004 8:02 pm
does anyone think it would be possible to overclock the FX-55 to 3ghz?
PostPosted: Wed Oct 27, 2004 8:39 pm
Celeron
Celeron
it'd probably be really hard... seeing that even 90nm chips cant break 2.7ghz (on air, of course).
maybe a snap of the fingers and a raise of the multipliers? :wink:
PostPosted: Thu Oct 28, 2004 3:07 am
Smithfield*
Smithfield*
well think of it in percentages. from 2.6 to 3 is an addition of 400Mhz so thats about 15-20%. i'd say its doable as long as you have quality components and cooling, which if you afford a FX-55 you must. give it a try and let us know.
PostPosted: Thu Oct 28, 2004 5:29 am
Hear! hear!
Only one way to find out.
PostPosted: Thu Oct 28, 2004 6:32 am
what speed of RAM do you think would be needed?
PostPosted: Thu Oct 28, 2004 7:56 am
i used to overclock k6-2's 20-25 percent using air cooling, but of course those things ran a lot cooler. Most likely the only thing stopping you is heat buildup. Also, you need overclocking memory, stuff thats faster then pc 3200, maybe 4200, because youl have to overclock the FSB and the memory is the main thing that will take the punishment(beside the cpu). You will also need some extreme cooling, im not talking just water cooling, thats not enough. More like a peltier /watercooling combo(where the peltier sits directly on a cold plate which sits directly on the die. The water cooling is used to disipate the heat generated by the peltier's hot side. People get sub-zero temps with that setup. You have to watch out for condensation and ice though(radiator required)) or you can consider using phasechange.
PostPosted: Thu Oct 28, 2004 9:15 am
To get optimal performance? I'd assume the faster the better, since hypertransport runs at 1ghz nowadays, right? Though low latencies are highly recomended as well.
PostPosted: Mon Nov 01, 2004 1:37 pm
well if all goes as planned the fx-57 will be 2.8ghx and probably the fisrt fx to be able to comfortably overclock to 3ghz :p
PostPosted: Tue Nov 02, 2004 4:45 pm
Smithfield*
Smithfield*
well dont hold your breath, AMD just released a new batch, it'll be a while before FX-57 and 4200+
PostPosted: Wed Nov 03, 2004 11:18 am
:o WOW!!! :shock:
I like the sound of that!!! Beating the Competition...GO AMD!!! :P
That's gonna be like a $1,000 CPU!!! The FX-53 is at $800, isn't it? :?
PostPosted: Wed Nov 03, 2004 1:00 pm
Likely it will just replace the current FX-55's price tag. Remember they don't have more than one FX proc in production at once.
PostPosted: Thu Nov 04, 2004 6:26 pm
Team Creamsicles
Team Creamsicles
there are fx-53 that are overclocked at 3.4 and 3.6.
PostPosted: Fri Nov 05, 2004 4:03 am
where did you find that?
PostPosted: Fri Nov 05, 2004 2:51 pm
It's been done with plain old watercooling, here are his bench results:
http://www.benchaddix.com - go to the post your scores here forum
Here is one at 3.6, but REALLY cold:
http://xtremesystems.org/forums/showthread.php?t=45095[/url]
PostPosted: Sat Nov 06, 2004 9:46 am
yeah well for those of us without liquid nitrogen handy, i think ill wait to get a 2.8ghz fx and do a 10% oc thank u very much.
PostPosted: Sat Nov 06, 2004 1:30 pm
Smithfield*
Smithfield*
yea i dont think too many people find maintaining a liquid nitrogen cooling system every week a viable option when then can knock down jsut clock just a bit and have a much easier less risky setup. the whole liquid nitrogen overclock is just to see how far a core can be pushed
PostPosted: Tue Nov 09, 2004 8:56 am
I've OCed myin to 2958 so far:
http://service.futuremark.com/compare?3dm05=264350
I hope that link works.
