It is currently Sun Jan 25, 2015 11:38 am
Do you use Cool Bits?
Yes, and my card OWNS you! 94%  94%  [ 16 ]
No, I like my card's rare, not well-done 6%  6%  [ 1 ]
Total votes : 17
 Post subject: Coolbits = Good or Bad?
PostPosted: Mon Nov 08, 2004 7:50 pm
Considering using coolbits but I just wanted some second hand opinions. Danke.
PostPosted: Mon Nov 08, 2004 7:59 pm
Team Member/ Ex-Team Member/ Team Member
I've used coolbits and it works well. Riva tuner is also a good choice.
PostPosted: Mon Nov 08, 2004 8:17 pm
Contributing Writer
Contributing Writer
Coolbits (or more specifically, coolbits2) saved me from an RMA, at least for the time being. I JUST finished making a thread describing my experience:
Linkage
PostPosted: Sat Dec 18, 2004 1:49 am
FYI:
You can do this without a download of any type of installer. Open regedit and travel on to HKLM/software/NVIDIA Corporation/Global/NVtweak.
Once to the "NVtweak" folder, right-click in the right pane and select "New --> DWORD value". Name this new DWORD "Coolbits". Double click "Coolbits" to open the properties and enter "3" into the value and insure the "hexadecimal" tic is filled.
Once you close regedit, you will have the overclocking utility installed in your display properties...and you did it all yourself, you hack:D
Users browsing this forum: LatiosXT and 5 guests
