It is currently Sat Apr 25, 2015 8:40 am
 Post subject: 3500+
PostPosted: Sun Oct 31, 2004 9:10 pm
Anyone here overclock an athlon 64 3500+?
If so how much and with what hsf, mobo, and ram?
 Post subject: Get a clue.
PostPosted: Mon Nov 01, 2004 6:23 am
You should go to www.overclockers.com . When you are there you should look up CPU Database. Then you just plug in your CPU type and go from there. Good luck. I will say from some experence, you will have no problems. I pushed my 2.0Ghz>>2.2Ghz. Which is pushing my AMD64 3200+>> to the same as AMD64 3500+. So you shouold be able to push your 3500+ to about the 3700+ range.
PostPosted: Sun Nov 07, 2004 4:55 pm
i'v heared the 2.6 to 2.7 range
