It is currently Sat Mar 28, 2015 9:06 pm
 Post subject: Which is the hotter chip?
PostPosted: Thu Oct 28, 2004 9:10 am
King of All Voodoo2 Cards
Does anyone know from experience which is the hotter running chip, the Intel Pentium 4 Prescott, or the AMD Athlon XP Palamino?
PostPosted: Thu Oct 28, 2004 9:16 am
I know from memory that the palamino was a toasty 50C or so while prescott runs even hotter (iirc)
PostPosted: Thu Oct 28, 2004 9:31 am
I've got a Throughbred B core that supposed to be cooler then the Palamino and it runs between 50C and 54C with a copper HSF from GlacialTech.
I figured the Palaminos might be a tad warmer.
PostPosted: Thu Oct 28, 2004 9:35 am
thats pretty darn hot, ive got a tbred-b in a cool (70-80) degree climate and it idles at 100 or so and peaks at about 115. (all temps in F). I use a thermaltake volcano9 and the fan is set manually to the lowest setting.
You may want to check heatsink seating and thermal paste.
PostPosted: Thu Oct 28, 2004 10:15 am
They're on there tight with Antec Reference thermal grease. Might swtich to Artic Silver 5 sooner or later, not sure if it'll make a difference because I think most of the heat comes from the VRMs which run at 54-57C.
PostPosted: Thu Oct 28, 2004 11:29 am
VRMs?
PostPosted: Thu Oct 28, 2004 11:47 am
Voltage Regulator Module
PostPosted: Thu Oct 28, 2004 12:12 pm
how come mine runs so much cooler then?
PostPosted: Thu Oct 28, 2004 12:56 pm
I've got more crap in my case generating heat.
PostPosted: Thu Oct 28, 2004 2:46 pm
*takes a healthy step back from the radioactive flytrap* :shock:
Seriously, whats in the case? Mines reasonably filled and I'm not big on fans.
PostPosted: Thu Oct 28, 2004 3:53 pm
[quote="urmumsacowSeriously, whats in the case? Mines reasonably filled and I'm not big on fans.[/quote]
6 Hard Drives, 4 Opticals, 2 Processors, a shitty Powercolor 9700 Pro, a Quantum Obsidian2 X-24 (fucking giant radiator), one ADSTech PyroLink Firewire card, a Hercules DigiFire 7.1 card, and 5 ribbon cables to block the airflow from 6 Vantec Silent Stealth case fans (which ain't so silent).
PostPosted: Thu Oct 28, 2004 4:21 pm
You may want to consider doing some consolidating :shock:
PostPosted: Thu Oct 28, 2004 4:45 pm
It gets the job done the way it's setup now.
The only minor annoyance I get is from the Powercolor card when I'm playing UT2k4 and it suddenly decides to hose my system right as I'm nuking an enemy power node. I can't wait to get rid of that thing.
PostPosted: Thu Oct 28, 2004 4:48 pm
Dare I ask what that job might be?
4 opticals.... what are you? A pirate?!
PostPosted: Thu Oct 28, 2004 4:53 pm
Well, I had the extra room in the case, and the extra resources, so I figured I'd give the Antec EPS12V 550W PSU a run for the money and see how much shit I could cram into it before the power supply would commit self immolation.
I guess it's not a surprise when it managed to put out enough juice for everything and then some, even when I started plugging in external bus powered 2.5" firewire drives.
Users browsing this forum: PCNoobiee and 5 guests
