It is currently Sat Mar 28, 2015 8:07 pm
 Post subject: Major heat problem!
PostPosted: Sat Oct 23, 2004 9:42 pm
for some reason my cpu idles at 55C-65C,,,WLF?!?!
amd xp 3000+ , 1 gig ram,,,,radeon 9800 pro,,,,stock fan,,,1 case fan,,,
What do i need to do? is this normal?!?!
PostPosted: Sun Oct 24, 2004 9:44 am
55c-65c idle is not normal. Doublecheck the heatsink installation and make sure the CPU fan is working correctly.
http://www.amd.com/us-en/Processors/Tec ... 78,00.html
PostPosted: Wed Nov 03, 2004 6:03 pm
I would assume there is no overclocking, but check to make sure you fans are facing the right way, (You'd be suprised) and clean off any dust, but past that Edward said it.
