It is currently Thu Mar 05, 2015 10:30 pm
 Post subject: 9600 Vid OC
PostPosted: Thu Oct 21, 2004 12:35 am
Hi everyone,
i've been out of the OC loop for a spell and i need to catch up... i've just recently gotten a visiontek 9600 256MB (325/195MHz) card and i want to know, what can i do to it?
I'd like to get hints, suggested setups, places i should go for more info and that sort...
like, can i do a BIOS mod on it?
what about voltage mods?
what kind of cooling should i go for?
what software tools are there available to monitor speeds, volts, temps?
thanks for any info!
-Egui
PostPosted: Thu Oct 28, 2004 7:54 am
A couple of things you could look at to get you started.
For my 9600XT I use an Arctic Ice Cooler Rev.3. I like it because it exhausts the warm air out of the case. I also plan to add some ram sinks at some point (unles I upgrade to another video card before hand).
For overclocking this card I use ATI Tool. It's free, easy to use, confirms the stability of the overclock and helps find the max stable overclock (just do not leave it running unattended).
I have heard of some volt mods but have not tried any myself.
