It is currently Mon Jan 26, 2015 5:30 am
 Post subject: Bought a used proc - What was done to it?
PostPosted: Fri Oct 15, 2004 4:19 pm
Hey all,
I just bought a used Amd 1700xp (JIUHB DLT3C stepping), and I have to admit, while I'm not new to overclocking, I am new to cpu modification.
Now, the processor came out of a K7S5A Pro, and is going into an ASRock K7S41GX (HTPC)
But after taking the processor out, I noticed that there was some electical tape keeping some wire inplace around 2 pins. So... I'm guessing the guy before me did some mod (multi mod?) to it seeing as the K7S5A doesn't support changing the multiplier. Then I noticed the L11 bridges are cut.
So... to what extent is this processor modded? Should I leave it in the K7S5A? The ASRock does support changing the multi if I remmeber right... I'm just not sure.
I guess my question is, what exactly was modded, and is it reversible? Need I reverse/remove it?
Thanks for any input.
PostPosted: Fri Oct 15, 2004 5:30 pm
After looking around a bit, it looks like the L12 mod. Which... I don't think I need.
