It is currently Sun Jan 25, 2015 11:39 am
 Post subject: Overclocking a PNY Geforce FX 5200 ultra...?
PostPosted: Thu Oct 14, 2004 9:58 am
About how far can it be overclocked safely? and what program should I use to do it?
PostPosted: Thu Oct 14, 2004 11:22 am
Astro lube 2 the MAX!
download coolbits. its a registry hack that allows the clocking options in the NVIDIA control panel in your display options.
Or use RIVAtuner to overclock.
I usually overclock to a speed till I see artifacting on the screen. Like video corruption. If you see that, slowly downclock it to a stable speed that doesn't inhibit the problems I listed. Then that will be your stable overclock. Not all cards are equal, so your overclocking results will vary.
PostPosted: Thu Oct 14, 2004 2:47 pm
So like how far do you think it could be overclocked? Like what range? 5600, 5600 ultra... thats what I mean.
Users browsing this forum: LatiosXT and 5 guests
