It is currently Sun Mar 29, 2015 4:04 pm
 Post subject: Trying to Learn
PostPosted: Wed Oct 13, 2004 9:07 pm
Well I built a new system over the spring and now that its been broken in a little, I would like to over-clock it a little bit... here are the specs:
ABIT IC-7G
2.8 Prescott P4 (with stock cooler for now)
512 of dual channel Kingston Hyper X ram (soon to be 1 gig)
Nvidia 5700 ultra (soon to be 6800 GT)
Sound Blaster Audigy 2 ZS
Couple of SeaGate Sata hard drives
6 cooling fans on an adjustbale fan regulator
X-Dreamer II case
Before I get my new ram and video card in, I'll be pulling everything out, painting the inside of the case (bling effect) and redrilling some of the airflow holes for better flow. What I wanted to ask is, is there a nice writeup somewhere about overclocking? I want to push the envelope a little bit... I'm not looking for neck breaking speed, just a little better performance. Thanks!
PostPosted: Wed Oct 13, 2004 9:12 pm
King of All Voodoo2 Cards
The easiest and most painless way is to see if your system board has one of those automatic overclocking options where when you hit 100% CPU usage it'll ramp up the FSB slightly. That would be the best way to get a little more performance without much risk to the hardware.
PostPosted: Wed Oct 13, 2004 9:26 pm
Celeron
Celeron
Flytrap, that's just about the worst way to learn how to overclock, am i correct?
Manual overclocks is where you'll learn the most. You get to manage temps, FSB's, maybe multi's, agp/pci locks, cpu:mem dividers, voltages, etc.
Step one would be to get to know your hardware. Figure out where your idle/load temps are, examine your cooling setup, and to know what things do in the BIOS.
Step two would be to know how to OC. OC'ing is a simple process with many factors in it. You can google "overclocking guide" and a site like this pops up. Read everything carefully.
Step three: Once you know what you're risking, and you're comfortable with them, go on ahead and slowly OC.
Step four: Stress your processor and record/remember what the load temps are. If there was a crash, back down the OC slowly, until you find the sweet spot.
note: god... we need a sticky
PostPosted: Thu Oct 14, 2004 5:54 am
what load times are you talking about?
windows?
PostPosted: Thu Oct 14, 2004 6:22 am
well I went into ABIT's soft menu and cranked it up to 2.92 ghz (2.8 stock) and the mobo wouldn't recognize my hard-drives. How wierd is that? And as soon as I brought the clock speed back down to 2.8, everything worked fine. I am going to buy a new Mobo friday and try OCing it again.
PostPosted: Thu Oct 14, 2004 7:59 am
Contributing Writer
Contributing Writer
Do you have reason to believe your mobo is faulty besides the quirky overclocking incident above? I ask because if you start replacing components everytime an OC goes south, it's going to be a much more costly affair.
You have a decent mobo, so unless there's another compelling reason to replace it, I'd urge you to tweak what you've got.
PostPosted: Thu Oct 14, 2004 11:31 am
well my little shit head of a brother ripped out the 10/100s socket so I was hoping to get that back... plus a buddy of mine wants to buy the old mobo and have me install it for the price of a brand new IC7G...
PostPosted: Thu Oct 14, 2004 8:07 pm
Celeron
Celeron
ROFL, go for it.
windows?
Load temps.
PostPosted: Thu Oct 14, 2004 8:12 pm
Celeron
Celeron
Make sure you have everything in tact. This is awkward even for a broken IC7-G. Sounds like a frequency problem with the PCI bus of some sort.
Did you lock your PCI/AGP frequencies?
PostPosted: Thu Oct 14, 2004 8:52 pm
no.. AGP and PCI were upped my 1 or 2 points each... like from 400 mhz to 401 or something (or whatever stock numbers are)... not a significant bump
PostPosted: Thu Oct 14, 2004 8:58 pm
Celeron
Celeron
uhh... since the PCI/AGP locks are FREE, and can do no harm, i dont see why you shouldn't lock them. Also, some devices are sensitive to even the littlest bump in frequencies.
PostPosted: Mon Oct 18, 2004 6:03 pm
Maybe I was thinking overclocking for AOL users?
He did say just a little better performance and for some strange reason I figured that'd be the absolute most foolproof way to get it, but yes, you're right, there's no knowledge/experience gained from it.
PostPosted: Mon Oct 18, 2004 7:55 pm
well I locked the PCI and AGP clocks and cranked the 2.8 to 2.9... same probelm as before where the computer won't recognize my Sata hard-drives (I only have Sata HDs). I'm going to swap in a new ic7G and see if the problem continues.
