It is currently Fri Feb 27, 2015 6:06 pm
 Post subject: Overclocking help
PostPosted: Wed Oct 13, 2004 10:35 am
BANNED
BANNED
I need some help deciding which case to get. I am stuck between the coolermaster praetorian, silverstone TJo5 and 06. I am planning on taking a 3.4ghz lgpa775 with an asus pdal2 premium to 4ghz. Which case would be the best to do that with? Also, whats the best cooling for my processor? I was looking at the thermaltake silent tower? Any suggestions would be very helpful.
PostPosted: Thu Oct 14, 2004 12:58 am
Astro lube 2 the MAX!
Well pick whatever case that fits:
1. price
2. looks
3. build quality
4. has good air flow. (ie: 2 fans intake, 2 outtake, etc...)
After that, make sure you buy a good aftermarket heatsink for your CPU.
From the looks of it, the Thermalright XP-90/120 are really good performers.
Someone else can suggest anything else. Thats just one input from me.
Or if you got good wallet full of green, go for watercooling if your serious about achieving good speeds.
Good luck! :)
