It is currently Fri Jan 30, 2015 3:54 am
 Post subject: super lanboy
PostPosted: Sat Sep 25, 2004 9:49 pm
im gonna get the antec super lanboy case and it was two 120mm fans, one front and one back
im gonna put a third one in the side, prolly 80mm
with this fan config, would it proper cooling for ocing?
PostPosted: Sun Sep 26, 2004 3:21 am
By itself, no. The case temps are relative to flow, which should be fine with just 2 of those huge 120mm fans. Now, if you clog it up with sloppy wiring then I say you won't fair too well. I'm just not convinced of the aid a side fan can give. I have never had one, and I've always had good OC's.
PostPosted: Sun Sep 26, 2004 9:18 pm
this is sorta unrelated but it still concerns the case
i bought the asus p4800-se mobo and when i went to put it my prefab case it was too big
i looked through my manual it said my case was a midtower
now will this mobo fit in the super lanboy? or am i screwed?
PostPosted: Sun Sep 26, 2004 10:23 pm
Uh, I can hear chumly's fingers start to ache as he types simlar things over and over again, so I am going to do it for him. (although not quite as well) :wink:
As you can see at the bottom of this page this mobo is a standard ATX motherboard. As long as a case is stated to be an ATX Case, any ATX sized motherboard should fit. Just because a case is a midtower.... or even huge, it does not mean that it will fit any type of motherboard. Most of the time nowdays, the midtowers would most likely be an ATX case.
this motherboard will definitly fit into the super lanboy.
