It is currently Sun Apr 19, 2015 1:49 pm
Post new topic Reply to topic  [ 593 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 30  Next
PostPosted: Wed Jul 13, 2005 7:26 am
Smithfield*
Smithfield*
I've got one of my 2400+'s up to 2.2 from stock 2.0. temp is at about 41-42 at full load. Will push it further tomorrow after a full burn in today.
PostPosted: Thu Jul 21, 2005 3:24 pm
I have a p4 2.4C @ 3.2GHz. I am using a Zalman 7000-cu HSF. Mobo is Abit IC7-G MAX II. I could go higher if RAM wasn't holding me back just a tad. Its 512x2 Performance OCZ DDR500
PostPosted: Sat Jul 23, 2005 8:50 am
I like dinosaurs
I like dinosaurs
Prescott 2.8 @3.65
xp120 heatsink
PostPosted: Sun Jul 24, 2005 9:07 am
I had my Pentium 4 Extreme Edition du-jour over clocked to 100 GHz with the motherboard submerged in a tank of liquid nitrogen. I managed to get 500 fps in Doom 3 before my system created a tear in hyperspace, disappeared into a black hole and has never been seen since. Word has it that an online gamer named "Satan" has commandeered my computer.
This is all true...honest!
PostPosted: Sun Jul 24, 2005 11:35 am
Million Club - 5 Plus*
Are you sure that it wasn't "DrSatan"? :lol:
PostPosted: Tue Jul 26, 2005 3:17 am
p4 northwood 2.4ghz currently at 3.05 ghz (with stock cooling ooooo baby)
PostPosted: Tue Jul 26, 2005 7:01 am
AMD socket 754 3200+ @ 2520. Here's info...
processor : 0
vendor_id : AuthenticAMD
cpu family : 15
model : 12
model name : AMD Athlon(tm) 64 Processor 3200+
stepping : 0
cpu MHz : 2520.084
cache size : 512 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 1
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 pni syscall nx mmxext lm 3dnowext 3dnow
bogomips : 4997.12
PostPosted: Mon Aug 01, 2005 10:09 am
AMD 2400+ Thoroughbred
@2.3GHz Overlocked, with Liquid Cooling.
PostPosted: Fri Aug 05, 2005 9:10 am
my 3000 + at 2.5 with arctic silver 5, and retail heat sink fan
PostPosted: Tue Aug 16, 2005 9:50 am
PostPosted: Fri Sep 02, 2005 7:36 pm
Monkey Federation (Top 10)*
I am posting this on a P4 Northwood 2.0, it is oc'd to 2.6. I had it to 2.89 but it was not too stable.
PostPosted: Tue Sep 06, 2005 2:47 pm
OVER CLOCKING IS THE DEVILS WORK
im good with stock stuff anyway lol
CS 1.6 all the way baby
PostPosted: Sat Sep 10, 2005 6:37 pm
Location: Defragging brain. Sector 25642401. Percent complete: 01000000%. 64-bit me.
PostPosted: Sat Sep 10, 2005 6:41 pm
athlon11 wrote:
What RAM do you have? DDR533? I couldn't kick my DDR400 over 450MHz. Then again, you have a Venice. I've got the original Winchester.
Nice clock!
PostPosted: Wed Sep 14, 2005 9:17 am
FX-55 San Diego.
1.4875 volts
2.8 GHz.
Completely stable even in a room that was at 90F.
The PROC runs at 35C idle and has goon as high as 52C under heavy load, I mean BF2 for 4 hours.
Cherish
8)
PostPosted: Wed Sep 14, 2005 5:44 pm
Athlon 64 3200+ from 2.0 @ 1.44v to 2.2 @1.49v
w00t.
PostPosted: Thu Sep 15, 2005 5:42 pm
just set up this puppy: X2 4800 running bout i think 433MHz faster in processor speed. can't really remember been a while since i was over at dad's.
PostPosted: Thu Sep 15, 2005 9:33 pm
Ggggeeeessssssshhhhhh........You guys are going to kill your A64s, such high voltages are not good. But then again, are those screenies just for show or do you guys "actually" run your processors at that speeds?
I run mine @ 4.0ghz & 1.33V, I know I'm not going to damage it, as long as I don't go above 1.45v. No need for CPU-Z, anyone can OC like that and get a screenie.
I keep this screenie just for show: @ 4.2GHZ & DDR2 1000
PostPosted: Fri Sep 16, 2005 5:12 am
nice but i don't really work my X2 proc that much. i checked with dad this morning and it's running 500MHz faster on EACH CORE. which is good. 1 GHz faster i would guess. but doesn't really help with games. also i have another one: AMD FX-57 running fast as heck! according to what i saw on newegg about my proc running from max safety limit of 1.4V to 1.55V. also it's a san diego core.
 Post subject: 3000+ Venice @ 3GHz
PostPosted: Fri Sep 16, 2005 12:10 pm
http://valid.x86-secret.com/show_oc.php?id=37753
I typically don't run 3GHz since it takes too much voltage, so below is my sig for daily operations and gaming:
AMD64 3000+ Venice 0517APJW 2.9GHz 1.55V with removed IHS
XFX Geforce 7800GTX 256MB OC 520/1400 on air 3DMark05=9072
DFI LP UT SLI-DR Rev AB0 Bios 623-2
Thermaltake Big Typhoon with 120mm Antec 2200RPM fan 29C/39C
Enermax Noisetake 600W SLi 2.01
Mushkin Redline 4000 2-2-2-6-T1 264MHz 3.5V Yellow Slots
Western Digital 74GB Raptor
Antec SLK3700AMB slightly modded for better airflow
