It is currently Sun Jan 25, 2015 9:09 am
Post new topic Reply to topic  [ 591 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 30  Next
PostPosted: Thu Mar 10, 2005 5:19 am
AMD 3500 Winnie @ 2.72 (272x10) in a DFI NF4 SLI-DR....won't break 36C under load with a new Corsair Cool. Had it at 2.8 (280x10) burt wasn't stable. Still tinkering to find the roof, but I think I'll hit 2.8 - 2.9 soon.
PostPosted: Mon Mar 14, 2005 8:29 pm
CM Praetorian blk case
Antec 550 PSU
Asus p4p800 se w/1000MHz FSB
p4 2.8c @ 3500MHz 25C idle & 35C under full load
Zalman CNPS7000B cpu cooler
1024 MBytes G.Skill PC4400 in DDR400 w/1:1 FBS:DRAM @ 500MHz
2.5-3-3-6 timing
4 80mm mdmm modded fans
Nexus multi-fan controller
I have not hit my ceiling!!
Entire System cost me less than $1500 to build.
Can I get a WoOt wOoT?
PostPosted: Sat Mar 26, 2005 9:20 pm
my first time trying this, p4 3.2@3.84
I am just using the 20% overclock setting in my bios on the asusp4p800-e deluxe.
any suggestion for a newbie?
PostPosted: Fri Apr 01, 2005 10:13 pm
Intel Pentium 4 Mobile 2.0Ghz OC'ed @ 2.73 on a desktop motherboard
Abit IC7-MAX
nividia GForce FX5600
2GB HyperX PC3500 CAS 2.0
C: 27Gb WD Raptor
TDK 52X CDR\RW
Sony 16X DVD-R\RW
SB Audigy Platnum eX
Gigabit Lan
ambient temp 80 degrees, temps while gaming
I can catch a fever higher than these temps!
enclosed- P4 stock heatsink and fan, no case fan, just what's on the PSU
standing a foot away, can't tell if its on.....w/o looking at the monitor :lol:
PostPosted: Sun Apr 03, 2005 8:56 am
Quote:
MAX:How about a 1400MHz increase, using a quiet permanent cooling solution. 995 MHz is easy territory for liquid, in some cases even air cooling.
Try this out...how about a 1199Mhz increase without water pumps, liquid nitrogen, a freon compressor, or the use of case fans?
One more to add to the taking...if it were measured from power save mode, it's a 1499Mhz increase simply on fresh air!
(ambient temp around 80degrees F)
Pentium 4 Mobile Processor 1.5 GHZ (speed stepped @ 1.2)
overclocked to 2699Mhz
ASUS P4B-533
-256Mb ram for safekeeping...and overclocked, 2699Mhz!
PostPosted: Thu Apr 07, 2005 5:37 am
CPU: AMD Athlon XP-M 2600+ (OC @ 2.4GHz @ 1.65v)
CPU Cooler: Thermaltake Extreme Volcano 12
Idle Temps @ 41c ~ 43c
Load Temps @ 47c ~ 49c
PostPosted: Sun Apr 10, 2005 2:04 pm
Brand new build! :D
Abit NF7-S
AMD Athlon XP-M 2200+ cooled with ThermalTake Silent Boost
2x512 Samsung 3200 DDR 2.5 3 3 6 I haven't played with the timings yet
Stock: 1800Mhz 13.5x133Mhz 1.45v
Temp: 32 C
Drystone: 7425
Whetstone: 2823
Integer x4: 16898
Floating Point x4: 17929
RAM Buffered Int: 2056 MB/s
RAM Buffered Float: 1973 MB/s
Best OC: 2310 Mhz 11x210Mhz 1.725v
Temp: 41C
Drystone: 9543
Whetstone: 3622
Integer x4: 21696
Floating Point x4: 23011
RAM Buffered Int: 3118 MB/s
RAM Buffered Float: 2919 MB/s
PostPosted: Sun Apr 24, 2005 9:58 pm
:lol:
PostPosted: Thu Apr 28, 2005 11:02 am
AMD 1.0GHz Duron Morgan @ 1.09GHz. Still trying for more.
PostPosted: Thu May 05, 2005 2:07 pm
Intel p4 3.0 w/HT OC'ed @ 3.21, still looking for the roof but this is my first time overclocking. any suggestions? warnings? how much hotter will my cpu get?
PostPosted: Sun May 15, 2005 6:04 pm
http://valid.x86-secret.com/ccpuz.php?id=18081
1.8GHz athlon 64 @ 2.195GHz
PostPosted: Thu May 26, 2005 7:15 pm
3.2e@3.71
dual xeons 3.06@3.41
PostPosted: Fri May 27, 2005 7:51 pm
Team Member Top 50*
Team Member Top 50*
Location: Folding in Ontario, Canada ------------------------- Team Rank: 44
Not as impressive in terms of Mhz but as a percentage, Celeron 366@572. That's a 56% overclock, without a voltage boost.
PostPosted: Sun Jun 19, 2005 4:40 pm
Right now, I haven't gone farther than FSB OC's, but I got my AMD socket 754 3200+ at 2500Mhz (guesstimated, it's like 2497). I am looking into the voltage and multiplyer settings, but I hear they are dangerous so I am going to be cautious about it.
PostPosted: Fri Jun 24, 2005 1:36 pm
PostPosted: Mon Jun 27, 2005 1:36 pm
A8N-Deluxe Mobo
AMD+3500 2.2ghz stock 2.7ghz OC
Ram at 2-2-2-5 1T
I have lowered the cpu to 2.4ghz stable though as of late. The watercooling i have will not allow it to run games at 2.7ghz.
PostPosted: Mon Jun 27, 2005 8:20 pm
ASUS A8N-SLI Deluxe
AMD Athlon 64 3200+ @ 2.3GHz
I think i posted my overclock somewhere but then I only had it at 2.2GHz.
PostPosted: Tue Jun 28, 2005 12:45 pm
ASUS A8V Deluxe Rev2.0
A64 3200+ @ 2.7ghz [270x10]
1x512mb PC3200 Corsair XMS
PostPosted: Sat Jul 02, 2005 5:33 pm
ABIT AG8-3rd Eye 915P
P4 650 3.4GHZ @ 4.0GHZ (4.2GHZ) 1.3xx load v.Core and 1.27xx idle v.Ccore :D
OCZ Plat EL Rev 2 CAS 2-2-2-5 @ 2.5-3-3-5 2.65V
Zalman pure copper heat-sink and AS5
All done on pure air.
I could go higher but I'd need water cooling or vapochill.....ah no thankx!.
PostPosted: Tue Jul 12, 2005 1:21 pm
this is nothing extreme but my 2500+ is chuggin along solid at 2310 with 1.675 vCore on a Tt Volcano 11
ram speed and latiencys are tightened from 2.5-3-3-11@ 400, down to 2-3-3-7@ 420 with 2.65V
