It is currently Tue May 05, 2015 10:31 pm
Post new topic Reply to topic  [ 593 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 30  Next
PostPosted: Thu Jan 20, 2005 7:10 pm
I know its BS but you can push a proc that far.
PostPosted: Thu Jan 20, 2005 7:15 pm
Smithfield*
Smithfield*
sure you could take a proc up 25%....people put xp 2500's past 3200 speeds all the time. but the 3.05....thats from windows. for example my xp 2400 reads a 1.99 instead of 2 ghz
PostPosted: Fri Jan 21, 2005 1:03 am
Hey! I'm using FireFox 1.0 now woot woot!
Thanksfilmbot for the concurence
[rant]I just love it when some kid comes in here and right off the bat straight to any bragging thread with his super rig , then followed by a 5 post newcomer who just happend to stumple across the same thread within 20 min and pat him on the back... :roll: sigh. thats my rant[/rant]
Me I'm an old schooler I recently mistook my dell system for garbage and acted accordingly bwhahahah :twisted: :!: Now I'm on my athlon 800 oce'd to 900 mhz I did get it to 1ghz but suffred from instability, i.e. windows would lock up, blue screen, etc...would push more, but I don't want to blow it like i did my older slot 1 system-you know your fuc*** when you can smell the capacitors burning)the rest of the specs are 256 31337 sdram and 20 gig wd caviar and a radeon 9200 running in 2x mode. Just think a 128 mb card in a 2 year+ old system .
It must think it's the best and I won't tell it otherwise.
 Post subject: Relics
PostPosted: Fri Jan 21, 2005 1:06 am
If anyone has a slot 1 pentium motherboard lying around I would gladly take it off your hands for a fair price. :wink:
PostPosted: Fri Jan 21, 2005 1:21 am
i currenlty have a Mobile 2500+ @ 2.4Ghz
PostPosted: Fri Jan 21, 2005 8:33 am
Minky Im not concurring with you at all.
I still think you are full of shit.
All Im saying is that it is possible to push a proc that far.
PostPosted: Sat Jan 22, 2005 1:14 pm
This one pwnzors ALL of yours!
3.0E overclocked to 2.99GHZ!!!! YAY!!
damn Intel cheapskates... they stole 10 mhz from me!
 Post subject: Re: hows this for power 4.00ghz CPU
PostPosted: Sat Jan 22, 2005 1:53 pm
nightfire007 wrote:
3 Gbs of RAM, Intel’s newest Mob and 3.05Ghz CPU, and to top it all off everything in the tower is water cooled, which allowed me to overclock the snot out of it to a grand total of 4.00Ghz. :D
give it up... your faking that... even if you did the 3.06ghz is a 533mhz FSB, old technology
PostPosted: Sun Jan 23, 2005 5:43 pm
Is it not even worth mentioning that you can't OC on an Intel mobo?
PostPosted: Sun Jan 23, 2005 6:17 pm
I overclocked my P III Celeron from 1300MHz to 1700MHz.
PostPosted: Mon Jan 24, 2005 2:10 pm
amd athlon 64 3500+ winchester from 2.2 to 2987 (zalman wattercooled)
PostPosted: Wed Jan 26, 2005 6:10 pm
M-Powered
M-Powered
Minky wrote:
I highly doubt that any Intel would take a 995 mhz increase
How about a 1400MHz increase, using a quiet permanent cooling solution. 995 MHz is easy territory for liquid, in some cases even air cooling.
PostPosted: Tue Feb 08, 2005 8:08 am
p4 2.0c clocked to 2720.3 / FSB 544.1
 Post subject: WANT MORE!!!
PostPosted: Fri Feb 11, 2005 3:11 am
AMD Athion 64 3000 2.04 runnin at 2.25, 6 internal fans, 1 turbo exhaust next to video card, 128 meg ati radeon, 1 gig 400 DDR, Abit KV8 Pro Mobo, temps between 99f- 145f. am thinging about water cooling, can I push it to 3.0. Screams in hl2, lovin it. fps off the edge compared to what I'm used to.
PostPosted: Tue Feb 15, 2005 4:45 pm
P4 2.6C runnin at 3.809 293 mhz fsb. Has been stable for about 9 months.
ASUS P4C800 mobo with 512mb Kingston ram WD hard drive and a Geforce 6800.
PostPosted: Sat Mar 05, 2005 5:59 pm
took my mobile 2600+ to 2409 - unfortunately i'm using old ram, so it's all multiplier on that one.
got my 3400+ to 2831 :) *sniff* life is sweet :)
There's a big lack of athlon64s in this thread :/ come on peeps - so what if the oc isn't as impressive, these chips respond so well to extra speed.
PostPosted: Mon Mar 07, 2005 11:26 pm
Former: AMD 1700+ o/c'ed to 2278 ( 217x10.5) now the kids.
Now : P4 2.4c o/c'ed to 3.2
Building: AMD 3500+
PostPosted: Tue Mar 08, 2005 1:05 am
How much voltage are you running to your cpu & memory?
 Post subject: "I have it cranked up to a whooping 504mhz!"
PostPosted: Wed Mar 09, 2005 8:25 am
1. Lower-case m in "504mhz" implies milli, so your processor is cranked down to .504 Hz(?)
2. If your processor really is running close to 1/2 cycle per second, I suppose "whooping" would be appropriate. But my guess is that you meant whopping 504MHz, which actually is impressive.
j/k, I'm just bitter 'cuz my 3200+ can't get past 2300. First, my 420W PSU is not enough to run all voltages at spec even at normal freq, plus it runs around 46C on die without OC, so I want some kind of active cooling.
Those are my specs, 3200+ @ 2300, more of a confession than a boast, but I'm working on it. Kudos to MaximumPC and all hardware hackers.
:cry:
 Post subject: Re: "I have it cranked up to a whooping 504mhz!"
PostPosted: Wed Mar 09, 2005 9:56 am
:cry:
Gluck with that about the only way your going to be able to get up your specs is to increase your multiplier. I would suggest moving to an M chip. I am assuming you are referring to an A socket chip.
