It is currently Mon Apr 27, 2015 6:25 pm
 Post subject: What is the best CPU fan for AMD Barton?
PostPosted: Thu Sep 16, 2004 4:21 pm
Heyya :wink:
I going to buy a CPU fan and a heatsink for my next coming Barton CPU...
Im searching for a good CPU fan and a heatsink that is:
1.Not noisy
2.Best in releasing the heat
3.Motherboard friendly...
Help me yea, :wink:
Thanks :D
PostPosted: Thu Sep 16, 2004 5:19 pm
Celeron
Celeron
Vantec TMD fan
good performance and end-user friendly. could be a problem with noise, though, from what i've read. it's not stupid loud, but its noticable.
next step-up: zalman cnps7000A al-cu/cu.
PostPosted: Thu Sep 16, 2004 7:19 pm
Super Folder
Super Folder
Thermalright makes the most effective AMD heatsinks, IMO. A tad heavy, but any properly mounted motherboard would have no problems. They're not cheap, however, but there is no beating them as far as heat dissipation for aircooling. Most Thermalright models have stepped ledges for easy mounting of multiple sized fans, which makes it easier to choose the best option to suit your acoustical and thermal needs.
PostPosted: Fri Sep 17, 2004 1:13 pm
I'd also recommend the Thermalright, but i'd pair it with a 92MM Panaflo fan, IMO the best fan on the market.
