It is currently Mon Jan 26, 2015 1:49 pm
 Post subject: Liquid Cooling Kit
PostPosted: Mon Sep 06, 2004 6:28 pm
Location: Kicking the crap out of the people who lied to me about using Folding@Home and those who declined!!
what cooling set up would u recommend for me?
ASUS P5AD2 Premium
Intel P4 3.4Ghz
ASUS X800XT PE pci-e
2x Crucial Ballistix 240-Pin 512MB DDR2 PC2-5300
RAM heatsinks and thermal paste
Antec 550W TrueControl PSU
or do u think i dont need it? how high do u think i can get out of this?
sry if uve already answered a similar question recently.
thanks in advance.
PostPosted: Wed Sep 08, 2004 5:24 pm
no answers......
PostPosted: Wed Sep 08, 2004 5:53 pm
(i) search the forum for similar questions
(ii) tell us what you actually want to do with that setup
(iii) tell us how much money you want to spend
(iv) tell us what systems you have looked at, and what you like and dislike about them.
PostPosted: Wed Sep 08, 2004 6:18 pm
too lazy but ill try...
overclock (obvious), game (thought that was obvious,) other stuff like internet. oh yeah try folding maybe.
I'd preffer not to spend over 300 but i will....if i have to...
I checked out the zalman resterator but im not sure if i want to too much, id also want a gpu cooler so i was wondering if i could get one w/ a gpu 1...
didnt u get a zalman lately...i think i saw it in the hardware haven?
what u get if yes?
 Post subject: Cooling Kit
PostPosted: Wed Sep 08, 2004 8:05 pm
I personally use the Koolance Exos
http://www.koolance.com/products/produc ... egory_id=2
I went with this system mainly because when the BTX formfactor kicks in I wanted to have a cooling kit that I could use without too many modifications (other than the cpu block of course). It was fairly painless to install as well and had better feedback overall than the Zalman external cooling solution.
PostPosted: Mon Sep 13, 2004 1:57 pm
DangerDen TDX 775CPU block with extra o-rings and nozzles: $57.94
HPPS 12v pump: $99
Hardware Labs 120mm BlackIce Pro radiator: $50
The choice of using a reservoir or not is up to you, but they're fairly cheap. At most, I say $50 here for something like the Innovatek Tank-o-matic plug-on. But there's cheaper ones, or you can just use a T-line fill port and forget the res all together.
With that, you have room left to get your tubing, cooling, and fittings. Avoid ADDING Innovatek fittings. They're purty, but they're expensive. If they're on there already, fine. These fittings can nickle-and-dime ya to death! I got into $50 of fittings last round before noticing. This time, I was a bit more alert. And don't forget the $18 fan.
PostPosted: Wed Sep 15, 2004 5:09 pm
HPPS 12v pump: $99
I agree with these components as a base. Especially the block. IMO TDX is da shiz. Rad is all dependent upon what/where you want it to be. If its in the case you may not have many option depending on the size of your case. I love big case with dual 120MM rads. You can get a smoking setup for under $300.
