It is currently Tue Jan 27, 2015 12:14 pm
 Post subject: Can my Motherboard handle this CPU?
PostPosted: Sun Aug 03, 2014 4:04 pm
Hi,
I was just wondering if my Motherboard can handle this CPU. The CPU I am thinking of getting is this http://www.amazon.co.uk/dp/B009O7YUF6/r ... 7G854201PZ
The Motherboard I have at the moment is the http://www.gigabyte.com/products/produc ... id=4305#ov
Will my Motherboard be able to handle this CPU?
Thanks.
 Post subject: Re: Can my Motherboard handle this CPU?
PostPosted: Sun Aug 03, 2014 4:30 pm
From http://www.gigabyte.com/products/produc ... id=4305#ov
Quote:
Supports AMD AM3+ FX/AM3 Phenom™ II & Athlon™ II series processors ...
To enable AM3+ AMD FX-Series CPU support, please update your motherboard with the most current BIOS found in your motherboard’s download section.
And http://www.cpu-upgrade.com/mb-AMD_%28ch ... /760G.html
I'd say yes.
PostPosted: Sun Aug 03, 2014 4:57 pm
Ok I have just updated my Drivers on my Motherboard.
Thank you for your help and for replying back to my post.
Users browsing this forum: No registered users and 14 guests
