It is currently Sun Jan 25, 2015 2:38 pm
 Post subject: Building New Gaming PC
PostPosted: Thu Jul 24, 2014 2:15 am
Hi, everyone. I am new member to the site and I would like some opinions on my new Gaming PC Build.
http://pcpartpicker.com/b/W3bj4D
My budget is about 1400,00 Euro but I would like to lower the price if possible.
Any suggestions?
Thank you all.
 Post subject: Re: Building New Gaming PC
PostPosted: Thu Jul 24, 2014 2:43 pm
Drop the processor to a i5-4690K. You won't lose much (if any) gaming performance. I'd consider getting a cheaper motherboard. You start buying "nice-to-have" features that most people never use when you go past about $120-$150. And you might want to get RAM that isn't so tall, as the CM 212 needs some clearance over the RAM slots.
Other than that looks good.
PostPosted: Sat Jul 26, 2014 1:59 am
You mean that with these RAM, the CM 212 won't fit?
If not, then the Corsair Vengeance will be OK? I hadn't
thought of the height... I will think about the i5 CPU.
Thanks for the other suggestions.
PostPosted: Sat Jul 26, 2014 7:19 am
The CM 212 is a huge heatsink, so as long as the RAM isn't any higher than "naked" RAM, you should be fine. Or low profile RAM, that works as well.
PostPosted: Sun Jul 27, 2014 4:21 am
Ok thanks for your suggestions.
