It is currently Sun Feb 01, 2015 6:53 am
 Post subject: Check out my build. (newbie here)
PostPosted: Wed Jul 23, 2014 8:37 pm
hey guys, im very new to building pcs, and i was hoping you could help me out here.
budget is low about (1000 to 1400$)
my case will be mini atx bitfenix prodigy.
and i need help to see if the ones here are compatible??
http://pcpartpicker.com/p/ZnfcGX
please do take the time to review it.
feel free to change a part if you think that theres a better option.
 Post subject: Re: Check out my build. (newbie here)
PostPosted: Fri Jul 25, 2014 7:02 pm
Welcome to the forums! I hope you enjoy building computers as much as I do.
Overall, very nicely done. Everything looks good...you're not underspending or overspending (in other words, you have a budget and you're spending it). My only suggestion would be to consider changing the PSU, perhaps the Corsair 600w version. It's modular, too, but is about $50 cheaper. And that $50, coupled with the wiggle room you still have in your budget could get you an nVidia 780. Just a thought.
Be sure you to post your results - I'd love to see some pics. I was eying that case so I'm interested how easy it is to build with it.
Hope this helps.
PostPosted: Sat Jul 26, 2014 12:16 am
Your builds looks good and very nice. I think that is ok to go for.
