It is currently Wed Jan 28, 2015 7:14 am
 Post subject: Build a PC help!!!!!!!!
PostPosted: Sat Jun 14, 2014 4:20 pm
I want to build a new computer for gaming and was looking if anyone could help.
Pricing 2000$-3000$
3 monitors for streaming only wanna play on the main screen.
Max fps on current games and what may come out.
I will be buying parts over the next 3 months, but want this built before fall. So if any new comp stuff coming out that's worth waiting for I will.
http://pcpartpicker.com/p/RxV2bv
Here is what I am considering. No clue on cooling or fans. The other choice I'm debating is 4770K and a Z87 motherboard, but I don't know how long the current setup would last as far as games coming out. If I would want to add another video card? I have a 550ti I could add to the computer as well from my old and no clue if that would even work. Was wondering if I could use for other 2 monitors to focus the 770ti on the main gaming screen.
Games I currently play are cs go, dota2, FF14, and a few others.
 Post subject: Re: Build a PC help!!!!!!!!
PostPosted: Mon Jun 16, 2014 8:08 am
changed the build A LOT http://pcpartpicker.com/p/rPVLwP
question about triple monitors I wanted the same company and same resolution. Is this the best pick up or would It be smarter to use cheaper brands or is there cheaper asus with the same resolution?
What fps would I get with this setup on max setting on today's currant games?
PostPosted: Mon Jun 16, 2014 8:14 am
If it's just the 1080p monitor, then most games will run 30FPS-60FPS depending on how high you cranked up the MSAA as well.
PostPosted: Tue Jun 17, 2014 4:06 pm
Hmm what can I do or add to make me get 144 fps and not drop below?
PostPosted: Tue Jun 17, 2014 4:16 pm
Depends. If you want maximum settings, add two more video cards (I don't believe adding just one will make everything 144FPS or higher). If you don't want to spend that much, drop the settings down.
PostPosted: Tue Jun 17, 2014 4:52 pm
hmm could you post a build that would just so I could see the cost? I think that would require a different motherboard right?
PostPosted: Tue Jun 17, 2014 4:54 pm
Hmm if its too costly I would prob add one more graphic card then upgrade processor a little and just lower settings a wee bit. To save money and get a steady fps, but still want to see the cost cause I have the $$ I think
PostPosted: Tue Jun 17, 2014 5:55 pm
Well it's easy, add the cost of the GPU you have. If you want another one it's another $700, if you want two it's $1400. But you have to get a bigger power supply too, so that's probably another $80 on top of the one you have. So total you're looking at almost $4000.
PostPosted: Tue Jun 17, 2014 5:58 pm
hmm idk if its worth all that >.< I'd prob add 1 graphic card and upgrade processor would I need a different motherboard?
PostPosted: Tue Jun 17, 2014 6:00 pm
Hmm and a power supply upgrade? guessing so as well
PostPosted: Tue Jun 17, 2014 6:09 pm
http://pcpartpicker.com/p/cH2Zzy would look like that..... any suggestions and still fits the budget :wink:
