It is currently Fri Jan 30, 2015 2:20 am
 Post subject: Power, Ports, and Mobo Build questions
PostPosted: Thu Jun 12, 2014 1:07 pm
Looking to build myself a new machine, it's been a few years, so I'm way overdue.
Here's what I'm looking at
From Newegg:
Motherboard: GIGABYTE GA-G1.Sniper Z97 LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX - $169
PowerSupply: CORSAIR CXM series CX600M 600W ATX12V v2.3 (Bronze) - $64.99
RAM G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) - $79.99
Storage: Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB - $54.99
OS: Microsoft Windows 8.1 64-bit - OEM - $99.99
Video: XFX Double D R9-280X-TDFD Radeon R9 280X 3GB - $299.99
Processor from Microcenter
Intel Core i5 4670K 3.4GHz Socket LGA 1150 Boxed - $189
I have a < 2 year old samsung 128 GB SSD for the OS, going to re-use that.
I have an optical drive I'll re-use for OS, maybe add a Blu Ray drive in, we'll see.
Price looks to be around $958 right now.
Here's my questions:
1) Power supply - I saw the XFX web site listing a 750 watt power supply, is that really necessary? They inflating that number in case you case you crossfire or something? I've seen a few posts that seem to indicate 500 is even enough - any thoughts here?
2) I have a case from 2009 that I'm using now. Safe bet the ports on the front aren't USB 3. Can I use those ports with the header on the Gigabye mother board and just not get USB3 speeds? Or are they different connectors completely?
3) Assuming I can't connect a USB3 header to the existing USB ports I have, anyone have recommendation for a decent inexpensive case? I want to be able to use those front ports. The case is under the desk, so I don't really care about looks. Just not annoying to get stuff into it and cooled well.
4) Motherboard- I went with a recommendation from the June Max PC builds. I don't have a problem with it, but I wouldn't mind saving a couple bucks if there's something equivalent that subtracts a feature I'm unlikely to care about. I do game, but I don't have a fancy set of speakers, usually have to keep the sound down anyway, so the sound stuff on this board may be more than needed. No plans to get a 2nd video card. not sure what else to throw in here.....
Thanks for your help, and if you have input on any of those parts - comments are welcome!
 Post subject: Re: Power, Ports, and Mobo Build questions
PostPosted: Thu Jun 12, 2014 1:44 pm
1) I use a 450W for a similar setup. It general consensus is 550-650W for this kind of setup, assuming 80PLUS certified.
2 & 3) USB 2.0 and 3.0 headers are different, but you can get a header converter if the board doesn't.
4) I'd shop around a bit. Boards I get typically float at $120 and they will do everything you need.
PostPosted: Thu Jun 12, 2014 3:58 pm
What about this Antec GX500?
Piggy-backing on what LatiosXT said, there are several quality motherboards in the $125 range. I would look at ASRock, MSi, Gigabyte or ASUS.
Hope this helps.
PostPosted: Fri Jun 13, 2014 10:41 am
Thanks for the feedback, guys!
I found what looks like the previous revision of that same board for about $133, so a nearly $40 savings, that's good enough. Assuming there's no compatibility issues with my i5 choice, but I think it's ok if I'm reading things right.
GIGABYTE G1.Sniper Z5S LGA 1150 Intel Z87 @ Newegg
Thanks for the information on the header / USB connectors. I'll debate what to do with the case for a day or so, probably end up just buying it.
PostPosted: Mon Jun 16, 2014 7:36 am
Wanted to add some useful information for the next readers of the thread. I was reading user comments on Newegg's site about the XFX video card I was looking at. I had questioned the power needs, and - this post from XFX support mirrored what the helpful folks here have been saying.
BUT - it's nice to hear it from them, right?
From
http://www.newegg.com/Product/Product.a ... 6814150678
a vendor response to a review.
________
Hello, We're sorry you are having issues with your card.
This unit requires a consistant 20+ amp PSU, very common. Anything Bronze Rated and 500 Watts should work without problems.
If you have any questions, please contact us at neweggsupport@xfxforce.com.
_________
