It is currently Mon Apr 20, 2015 10:14 pm
 Post subject: Gaming PC
PostPosted: Mon Jun 02, 2014 10:16 am
CPU: AMD FX-6300 3.5GHz 6-Core
CPU Cooler: Arctic Cooling Freezer 7 Pro Rev.2 45.0 CFM Fluid Dynamic Bearing
GPU: Gigabyte GeForce GTX 650 2GB
MOBO: MSI 760GM-E51 (FX) Micro ATX AM3+
RAM: AMD 8GB (1 x 8GB) DDR3-1600
HDD: Hitachi Ultrastar 1TB 3.5" 7200RPM
PSU: Corsair 600W ATX12V
Case: Aerocool Strike-X One ATX Mid Tower
AMD FX-6300, Gigabyte GeForce GTX 650, Aerocool Strike-X One - STONED GAMING - dio93's Saved Part List - PCPartPicker
what do you think? :roll:
and what do you suggest ? :!:
Budget & currency: 650 - 700 euros
Purpose of build: gaming
Intended games or applications: cs:go , bf4, lol
Any preferences: windows 7
 Post subject: Re: Gaming PC
PostPosted: Sun Jun 08, 2014 5:20 am
Everything looks compatible. Depending on the price difference and if it's within your budget, I would move to the newer 750 or 750Ti.
Hope this helps.
