It is currently Tue Mar 03, 2015 8:47 am
 Post subject: disable intergated
PostPosted: Sun Mar 30, 2014 12:21 pm
Would I need to disable intergrated graphicson the Gigabyte Z87X-UD3H mb? I have a EVGA gtx 760 video card installed. Monitor is hooked to video card not MB.
 Post subject: Re: disable intergated
PostPosted: Sun Mar 30, 2014 12:51 pm
No. If you've left it on auto configuration, the computer is smart enough to disable it anyway. And even if you left it on, the most that'll happen is you lose like 300MB of usable RAM.
PostPosted: Sun Mar 30, 2014 12:58 pm
cool, thanks. In device manager it shows both enabled. Was just wondering if they would interfer. Thank you again.
PostPosted: Sun Mar 30, 2014 1:01 pm
Windows has been pretty good with heterogeneous setups. I think the whole integrated stuff interfering with hardware has been long dead since XP.
 Post subject: Re:
PostPosted: Mon Mar 31, 2014 3:20 pm
Yes, most do switch automatically. I had no problems with this using Linux either. The only time I did have to configure it was when I had one card for Folding@Home and wanted to use another card just for the monitor.
