It is currently Fri Jan 30, 2015 10:14 am
 Post subject: m5a99x evo r2.0 and fx 8320 will i have any problem?
PostPosted: Sat Mar 29, 2014 9:02 pm
I have heard that the bios that came with the m5a99x evo r2.0 have problems with the fx 8320. If that's the case, what should i do? If i got to update the bios, i have to do it with another cpu (which i dont have) or without one it would work?
I dont know too much about this so excuse if the answer is obvious :)
 Post subject: Re: m5a99x evo r2.0 and fx 8320 will i have any problem?
PostPosted: Sat Mar 29, 2014 9:22 pm
You need a compatible processor first to update BIOS.
PostPosted: Sun Mar 30, 2014 11:29 am
Unless it is an ASUS MB--which it is--in which case you can update the BIOS even without a CPU or RAM present using their USB BIO Flashback which I wish everyone would build into their system.
PostPosted: Sun Mar 30, 2014 12:53 pm
I wish everyone did dual-BIOS, but I'm pretty sure this is all patented trademarked crap.
PostPosted: Sun Mar 30, 2014 1:39 pm
Thanks for your help:)
