It is currently Fri Feb 27, 2015 9:13 am
 Post subject: 1st time building a gaming PC, need some comments on my rig
PostPosted: Mon Mar 24, 2014 4:49 pm
CPU Intel Core i5-4670K
Motherboard MSI Z87-G55
Memory 8GB Corsair Vengeance DDR3 1600MHz Low Profile 2(4GB)
GPU ASUS GTX760-DC2OC-2GD5 GeForce GTX760 2GB GDDR5 256-bit, DVI-I/DVI-D/ HDMI/DP PCI-Express 3.0 SLI ready Graphic Card OC-selected 1072 MHz core
Case Corsair Carbide Series 200R Windowed Compact ATX Case
SSD/Hard Drive Samsung Electronics 840 EVO-Series 250GB 2.5-Inch SATA III / Western Digital Black 500GB Hard Drive
Optical Drive OEM Blu Ray Drive
PSU Antec EA-550 Platinum 550W PSU
OS Windows 7 64-bit or Windows 8.1 64-bit
cooling system Noctua 6 Dual Heatpipe with 140mm/120mm Dual SSO Bearing Fans CPU Cooler NH-D14
uhhmm im not sure if the PSU is good, also im not sure if they will all fit in the case. regarding the ram, instead of the 8GB one on top, shoud i get this "Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory".. thank you for the patience in helping me, I appreciate it.
here are some additional items i might buy
Monitor Dell E-Series E2414Hr 24-inch Monitor
Sound Card Creative Sound Blaster Z
Keyboard Razer BlackWidow Ultimate
 Post subject: Re: 1st time building a gaming PC, need some comments on my
PostPosted: Tue Mar 25, 2014 7:03 am
The power supply looks good enough to run your rig with an upgrade down the road and some overclocking. As for the amount of RAM, stick with 8GB for now. If you find yourself running out, you can always add another 8GB.
