It is currently Fri Mar 27, 2015 11:08 am
 Post subject: Triple Monitor Help????
PostPosted: Fri Mar 21, 2014 8:52 am
Hi I'm New Here But I need help about this topic????
It's that I want To Set-up Three Monitor In One Machine(CPU)???
Is it possible???
My Specs Are!!!
CPU :- AMD FX 8350(Can OC Upto 4.5 GHZ)
GPU :- Asus GTX 660TI(2 Way SLI)
RAM :- 4GB DDR3@1300MHZ :/
Motherboard :- MSI 970A-G46
PSU :- Corsair 1200W
My Question Is Can I set-up Three Monitor???
I already Have One!!
Monitor Specs!!!
18Inch(1336 x 768) Resolution!!
Want To Connect Three Monitor Of Same Monitor Specs!!!
Is It possible??
What Else I need To Upgrade???
And Also How Do I???
But Explain Me In Detail!!!
Thank You People!!!! :)
~P[R] ANAY
 Post subject: Re: Triple Monitor Help????
PostPosted: Fri Mar 21, 2014 10:15 pm
Yes, you can plug in three monitors. Doesn't really matter which video cards but for each graphics card you need at least one plugged into the DVI port.
