It is currently Sat Apr 25, 2015 10:52 pm
 Post subject: Multiple Fans
PostPosted: Mon Mar 17, 2014 10:36 pm
Whats the best way to connect multiple fans and have them pushed to 100%? Should I just connect it straight to the psu or should I use a fan controller?
 Post subject: Re: Multiple Fans
PostPosted: Mon Mar 17, 2014 10:48 pm
You don't want to push fans to 100% unless you have a reason to.
But if you insist, directly from the PSU.
PostPosted: Mon Mar 17, 2014 10:59 pm
Should I use a y spliter to molex or can is their a way to solider them together?
PostPosted: Mon Mar 17, 2014 11:11 pm
Either way works.
PostPosted: Tue Mar 18, 2014 8:57 am
How would I exactly splice the wires and is their a limit to how many fans I can connect?
http://www.google.com/imgres?sa=X&rlz=1 ... =0&ndsp=37
PostPosted: Tue Mar 18, 2014 9:43 am
why not just buy adjustable speed fans?
PostPosted: Tue Mar 18, 2014 10:05 am
Don't ask. Just play along. :3
That picture is correct, except they cut the yellow wire which is 12V. If you want the fans running at full speed, they need that connected instead of the 5V red wire (don't connect both). As far as how many you can connect, assuming each fan takes up 0.6A @ 12V, with the specification being 11A maximum ( https://en.wikipedia.org/wiki/Molex_con ... nnector.29 ), you can fit about 20-22.
PostPosted: Tue Mar 18, 2014 11:10 am
I've read that the yellow wire was the rpm controller?
PostPosted: Tue Mar 18, 2014 12:17 pm
That's not a fan that plugs into the PSU then. That's a fan that plugs into motherboard headers. That I'm not sure how many you can plug in at once.
PostPosted: Tue Mar 18, 2014 3:53 pm
I see, I currently have 16 Corsair AF120mm Red LED fans and Im trying to have it wired and look clean compared to using a 2x3pin split to 1x3pin to a molex connector.
PostPosted: Tue Mar 18, 2014 4:32 pm
ninjastar wrote:
I see, I currently have 16 Corsair AF120mm Red LED fans.
:shock: :shock:
You want to turn your room into a jet engine?
PostPosted: Tue Mar 18, 2014 4:41 pm
Well, in your case, then yes, it'd be better to get a fan controller. But you'll need at least 3, most only have 5-6 channels.
PostPosted: Tue Mar 18, 2014 5:04 pm
So with that type of fan I would have to connect it to a fan controller instead of directly to the psu?
Also whats your thoughts of water cooling with koolance/xspc?
PostPosted: Tue Mar 18, 2014 5:59 pm
This, not this
PostPosted: Tue Mar 18, 2014 6:55 pm
Well I do have a the molex to 3 pin connector, so can I just replace the 3 pin male adapter and solder all of 2-4 of them to it?
PostPosted: Tue Mar 18, 2014 8:10 pm
Sure, if you want.
